Thread: engine management
    Jan 2013
    Newtyle
    Default engine management
    hi everyone..... i was wonder if anyone could help me....
    the engine management light on my vectra c 1.8 05plate
    the code is po136 - generic o2 sensor circuit malfunction (bank 1 sensor 2)
    is that mean the lambdo sensor???
    also other code is c1555 - GM DTC definition not found please refer to vehicle service manual
    what that mean???
    if anyone would help that would be cheerful and useful
    thanks
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Yes the 0136 is the 2nd lambda sensor.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    It's front O2 sensor heater circuit.
    can test with a multimeter expect 4-8ohms
    Jan 2013
    Newtyle
    great thanks but which one front or second lol
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    That code is generic code for front heated O2 sensor
    but testing across the 2 white wire with ohm meter will prove it
    9/10 they go open circuit
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    I was under the impression position 1 was pre cat and position 2 post cat?
    Jan 2013
    Newtyle
    brills i will check tomorrow also i need new radiator becuase just had burst it after fitted new thermostat but radiator look bit rusty on edge so anyway....... so what i do it i will go scrappy get radiator and some spare for vectra and will test the lambdo sensor will update tomorrow thanks again for help
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Whoops that's my bad. Just checked and you are correct it's rear O2 ie post cat.
    and it's also relating to the actual operation of sensor so would need to reading voltages.
    Taxi for one please! :couch:
    Right ill stop assuming I know codes and check next time
    some info they may or may not help
    Over 450mv is reading rich so commanding lean and below 450mv is lean so commanding rich
    best way to check if its reading rich cause a lean condition ie create a vac leak
    if it's reading lean spray some carb cleaner into intake.
    voltages should adjust accordingly in under 100ms
    also go for drive check that it goes into closed up.
    Rev to wide open throttle and see what happens to O2 voltage.
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    Only reason I know that code is mine throws it about once a fortnight critch, lol. 0036 is the heater and 0136 is the actual operation. Been like this for the 2 1/2 years ive had it, just waiting for the flexi to finally give up the ghost and ill buy a new one to put in the new front pipe i have in the loft.
  1. Engine lumpy now Engine Management Light is on
    By Fitzy-2.0T in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2012, 16:51
  2. Egr valve / now engine management ?
    By steveo273 in forum Introduce yourself.
    Last Post: 20th November 2010, 22:34
  3. Engine Management Light 2.2 DTi
    By timv128 in forum Vectra C / Signum Troubleshooting
    Last Post: 14th November 2009, 17:33
  4. Replies: 3
    Last Post: 28th April 2009, 19:49
  5. just had engine management done
    By MAF 3.2 V6 GSi in forum Vectra C / Signum Car Chat
    Last Post: 29th June 2007, 19:25
