Results 1 to 2 of 2
Thread: Driver Side Fascioa Air Vent Noise
    Feb 2011
    Default Driver Side Fascioa Air Vent Noise
    The driver side Fascia Air Vent is making a roaring whistling noise when I am speed and into a strong headwind. Espicially bad when you get the 'Ram' effect of a vehicle going the other way. I took it off ,(easy) and replaced the foam strip between it and the duct but still got problem. Took it to Main Dealer and they had never seen the problem and couldnt help. It is present at all settings of the Ventilation Control knob and even when I set to 'in car recirculation'. Is there a flap or something that is staying open? Any help greatly appreciated.
    Merryterry
    Feb 2011
    Quote Originally Posted by Merryterry View Post
    Merryterry
    I am wondering if this is a blown fuses/fuses on the selenoids to the flaps that control the different air control directions. When I used to change them you could hear the flaps close as you changed. Now I cannot hear anything when I change the air directions?
    Merryterry
  1. loud whirring / hoover noise from front driver side
    By Drazek in forum Suspension, Wheels & Brakes
    Last Post: 2nd May 2011, 17:10
  2. Driver side door / Clicking noise
    By bizerk in forum Bodywork & Interior
    Last Post: 22nd September 2008, 18:56
  3. Front driver side spring noise
    By barracuda in forum Suspension, Wheels & Brakes
    Last Post: 14th February 2008, 11:23
opel vectra c air vent noise
