Thread: How to remove roof rail?
    liverpool
    Default How to remove roof rail?
    I have already asked this question and been helped with pics but still struggling. In an effort to stop water leak in boot trying to check rivet which believe can be a cause under the roof rail. Have lifted both flaps pulled all the clips out on inside but the boot end is still firmly in place. What is method/technique needed to remove it. Thanks
    Jan 2013
    yorkshire
    Have u sealed aerial base that's 90% at fault for water in boot etc I had water inboot sealed aerial. Now no water.
    liverpool
    Quote Originally Posted by daddy5times View Post
    Yes fitted new aerial base and sealed it at same time. Now checking other possible areas that leak.
    liverpool
    Is anyone able to offer any help
    scotland
    it can be prised up from the rear first , put a screwdriver (or similar) under it at rear , use a rag so not to damage paintwork , then GENTLY prise it upward .
    liverpool
    Quote Originally Posted by gsxrster View Post
    Cheers for help. Will try in morning
  1. Roof rail rivet
    By daddy5times in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2013, 23:27
  2. Roof rail help needed please
    By eve01rton in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2013, 23:13
  3. Remove roof lining
    By daddy5times in forum Bodywork & Interior
    Last Post: 26th January 2013, 08:52
  4. Roof Bars ~ how to remove?
    By j3cpg in forum Styling
    Last Post: 25th January 2010, 13:26
vectra c roof rail removal
