Thread: so dpf's ...... what do i need to know
    Jan 2013
    rosyth
    Vehicle : vectra
    Trim : sri
    Engine : cdti 150 auto
    Default so dpf's ...... what do i need to know
    Good afternoon folks
    Had various diesels but never had a dpf
    What do I need to know ?
    Do I regenerate it ?
    Is there a special fluid for it ?
    How do I keep it in good working condition ?.........
    Without removing it physically or mapping it out just yet
    Thanks for reading
    Mick
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Quote Originally Posted by big mick 1981
    It'll really ruin your day if it goes wrong!
    No it'll do it itself. Just don't keep doing short journeys where it doesn't get hot. This is what clogs it up.
    Apparently there's a few on the market to help clean them but drive it properly and it won't be needed.
    Allow it to get hot and every couple of weeks give it 20 minutes or so on the motorway to regen itself. You'll see your fuel consumption go up when it's doing a regen.
    Regular Member rockafella8587's Avatar
    Nov 2011
    Akrotiri, Cyprus
    Short journeys are generally bad for it and dont let it regenerate. A long blast along the motorway is what it needs to enable it to reach a high enough temperature for it to regenerate. Never switch the car off whilst its happening. You will notice a drop in mpg and performance during a regen. Mine was clogged up and was putting the car in limp mode so its now in a skip somewhere
    Jan 2013
    rosyth
    Vehicle : vectra
    Trim : sri
    Is there no light to warn you when in regen mode ? If not would there be a cable to tap into to warn you it's doing a regen ?
    I do 25 mile to work and 25 back everyday sitting pretty much constantly at 50-60 mph, does this sound sufficient ?
    Full Member Penfold101's Avatar
    Quote Originally Posted by big mick 1981 View Post
    When they first brought them out, the glowplug light would flash when it was regenerating. Then people would be bringing the car in to the garages because they couldn't RTFM, so VX changed the software so you didn't know it was happening...
    That journey sounds fine - the engine will be up to temperature but it means it'll need to do a full regen. Usually, if you're above about 2000rpm (I think) the exhaust gasses are hot enough to regenerate the filter through normal driving, or at least stop it building up so quickly. A good thrash every now and then helps it too. It'll take care of itself generally, but when you pull up check out the instantaneous fuel consumption and if it's much higher than normal (normal is around .1/.2 gallons per hour) then it's doing a regen and you need to leave it to finish before turning the engine off. Revving it will help speed it up a bit...
    Full Member Teapot's Avatar
    woodbridge, suffolk
    66 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    Quote Originally Posted by rockafella8587 View Post
    Mine will go the same way if it ever malfunctions - but my driving seems to keep it in good order so far...
  1. An FYI for DPF's
    By Barlow in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2015, 14:37
  2. twin exhaust and dpf's
    By Grumpy1954 in forum Styling
    Last Post: 1st June 2011, 03:41
  3. DPF's EGR's and Tuning Boxes
    By R6Kev in forum Engine & Drivetrain
    Last Post: 27th August 2010, 19:29
  4. An interesting video for those of you with DPF's
    By John LE in forum Diesel Engine related
    Last Post: 21st July 2010, 09:03
