Thread: Traction Control
    Regular Member swalk999's Avatar
    scotland
    Unhappy Traction Control
    hi I have just bought a 2004 sri 2.2 and I thought that the sri had traction control fitted as standard but i dont have a traction control button on the dash.
    so i taks it its not fitted
    steve
    Regular Member simac's Avatar
    Wirral
    I think it's standard on all SRI's except the 1.8. It doesn't come with a button to turn it off (although you can fit one to most).
    When you turn on the ignition what amber lights do you get in the centre of the dash? by the ABS light ? there should be a t/c light there too which goes out on startup - unless there is a problem
    HTH
    Oct 2006
    Yorkshire
    the warning light on mine is a little triangle with skid marks through it in the middle of the dash.
    Failing that find an icey patch and wheelspin it, the light should flicker on to tell you it's activating.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Your T/C is on all the time mate. The button you can get only turns it off.
    Here, there and every where!
    You can get the T/C button from the dealers for less than a tenner but it is hit and miss as to whether it works or not (to turn it off as its on all the time)
    If you have 3 buttons either side of the steering wheel for the radio controls then it normally does.
    Vehicle : SRi
    Mileage : 137000
    I works in my 2.2 2004 so you might be in luck.
  1. my traction control how to
    By jpbroad1970 in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2012, 20:01
  2. traction control
    By ggg1979 in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2009, 18:07
  3. 2.0T Traction Control
    By kryton01 in forum Engine & Drivetrain
    Last Post: 20th October 2009, 17:18
  4. traction control
    By jsnlvxr in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2009, 21:56
  5. traction control
    By jamesv6 in forum Vectra C / Signum Car Chat
    Last Post: 14th August 2006, 00:13
vectra traction control flicker
