Thread: Low mpg, cdti 120
    Regular Member Learch's Avatar
    Jan 2013
    Chester
    Vehicle : Vectra c
    Trim : LS
    Engine : Cdti 8v
    Default Low mpg, cdti 120
    I've got an 04 120 cdti and I'm struggling to get just over 40mpg out of it. I know it needs a thermostat and the mpg wasn't that bad until the eml came on the other week. I had it read and it was a boost sensor deficiency, inactive, so cleared it and replaced a perished vacuum hose. I've taken my tuning box off but it's still struggling to get 45 mpg. Could the boost converter valve by the slam panel be knackered and could this cause excessive fuel usage?
    Jan 2013
    Chester
    Vehicle : Vectra c
    Trim : LS
    Engine : Cdti 8v
    Anyone?
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Thermostat can affect mpg
    Jan 2013
    Chester
    Vehicle : Vectra c
    Trim : LS
    Engine : Cdti 8v
    Well I know it needs doing so ill try and get round to changing both just to be sure. Thanks for confirming what I thought.
    hull
    Mine only averages 40-43mpg (taxi), thought it was normal. Up to 55mpg at 70mph on a run though, urban mpg not so great on these cars, a bit heavy i think.
    Jan 2013
    Chester
    Vehicle : Vectra c
    Trim : LS
    Engine : Cdti 8v
    Quote Originally Posted by frasedeb View Post
    That sounds like mine. Was very good on a 300 mile round trip but doing 40 miles to work and back every day it seems lower that expected. I'm using about half a tank to do 250 miles
    hull
    Quote Originally Posted by Learch View Post
    I didn't add that my thermostat also needs doing but still find 40-43 mpg is poor. Used to get 60mpg average out of my previous picasso 1.6hdi but the vec is a far better drive.
    Jan 2013
    Chester
    Vehicle : Vectra c
    Trim : LS
    Engine : Cdti 8v
    Well I managed to do my stat yesterday, not the easiest job as someone at vauxhall decided to make the bottom bolt a stud for the egr system. I also did my egr blank while I had it out, temp gauge actually works now and the stat started to open so ill see by next week Thursday if its any better on fuel.
    Regular Member Vectra-c-SRI's Avatar
    May 2008
    Near Glasgow
    Engine : 1.9cdti 8v (120bhp)
    Mileage : 98000
    Where is the temp sensor you changed can't find it lol (120bhp)
    Jan 2013
    Chester
    Vehicle : Vectra c
    Trim : LS
    Engine : Cdti 8v
    Quote Originally Posted by Vectra-c-SRI View Post
    Didn't notice you had replied, sorry mate. The temp sensor is in the thermostat housing. The stat was a right pain in the arse to change. If you take the engine cover off and then look down the right hand side of the engine, between the boost pipe and the head but lower down you'll see the stat, there should be 3 smaller pipes, a larger one and the sensor there.
    I ended up changing the leak off pipes and fuel filter and its up to 46-48 mpg now so I'm happy with it for now. Would still be nice to be getting 50+ but it's better than 40-42. Over the 800 mile month it's a big enough difference.
  1. 1.9 Vectra CDTi 150 VS 2.0 CDTi 160 insignia Sri
    By Derek Mc in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2011, 11:38
  2. Weird noise from Signum CDTI 1.9 CDTI (150)
    By oneightycd in forum Diesel Engine related
    Last Post: 22nd June 2007, 22:27
  3. CDTi 120bhp Vs CDTi 150bp
    By bennyk in forum Diesel Engine related
    Last Post: 6th December 2006, 23:45
