Results 1 to 10 of 22
Thread: A bit baffled,and nervous!
    Regular Member toaffer's Avatar
    Sep 2011
    Fife,Scotland
    Trim : SRI
    Engine : 1.8 VVT (Z18XER)
    Mileage : 73K
    Default A bit baffled,and nervous!
    Hello fellas,I've got a Z18XER petrol engine in a 1.8 SRI,strange one this,started up car tonight to go to work and heard a muffled sound like a slightly blowy exhaust when reving engine,just got back home and noticed than when I pulled out dipstick to check oil it began running lumpy and a bit worse when I took off oil filler cap,car ran normal driving home,no noticeable loss of power,engine temp ok,no dash warnings and the water in reservoir looks clean (in case of CHG failure),I hope its just a loose hose or something as funds are at an all time low,any help with troubleshooting this much appreciated,cheers
    Jan 2013
    warrington
    Totally normal on the Z18XER engine, something to do with negative presure or something in the crank case. Mine does it, dont know the exact science behind it but defiently normal on this engine.
    Sep 2011
    Fife,Scotland
    Trim : SRI
    Mileage : 73K
    Quote Originally Posted by stephengreen1980 View Post
    Cheers for letting us know Stephen! well thats half the symptoms cured, had a good look see again couple of hours ago and still making a blowing noise in engine bay, its not loud but def was not there couple of days ago and engine not running as smooth sometimes sounds like a "quite" diesel if that makes sense,its basically when you give her some revs you hear the blowing but no indication somethings wrong when driving as normal.
    Jun 2011
    Buckley Flintshire N.Wales
    Vehicle : vectra
    Trim : .....................
    Engine : ....................
    Year : .....
    Sounds like a leaking exhaust manifold,had the same symptoms on my last motor took the heatshield off and the manifold had a crack in it
    Sep 2011
    Fife,Scotland
    Trim : SRI
    Mileage : 73K
    Hmmm thats what I am dreading Patch, how much to replace the manifold if you dont mind me askin? Hopefully just a gasket!
    Jun 2011
    Vehicle : vectra
    Year : .....
    Cat was all part of the manifold think its called a manicat or something like that,I got used one from a breakers through flea bay cost me £80 and it was fine after that no emission issues at mot time,so I got off lightly,new ones are very pricey I believe
    Sep 2011
    Fife,Scotland
    Trim : SRI
    Mileage : 73K
    Quote Originally Posted by patch22 View Post
    Well Im just off the phone to my local Vaux Stealer and £580+ VAT and thats just for the part! Hoping It aint the manifold then!!! will take it to a garage asap to get confirmation, cheers
    Jun 2011
    Vehicle : vectra
    Year : .....
    Hope it works out cheaply for you mate
    Sep 2011
    Fife,Scotland
    Trim : SRI
    Mileage : 73K
    cheers Patch! Will find out in a few days )
    Jan 2013
    rosyth
    Vehicle : vectra
    Trim : sri
    Engine : cdti 150 auto
    You can always get a cracked mani welded, cast or not . Just get whoever is welding to drill holes in each end of the crack to stop it spreading
  1. baffled?????????
    By eve01rton in forum Vectra C / Signum Car Chat
    Last Post: 2nd February 2013, 18:16
  2. A nervous hello from Yorkshire
    By wolfie78uk in forum Introduce yourself.
    Last Post: 8th May 2012, 11:54
  3. baffled
    By alijlacy in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2010, 21:02
  4. Nervous as a turkey at christmas
    By steveked in forum The 'Off Topic' room
    Last Post: 12th June 2008, 21:38
  5. Starting to get nervous.........
    By spoons in forum Irmscher Factory Road Trip - 13-16th April
    Last Post: 11th April 2007, 21:08
