Thread: doing the clutch tommorow on 1.9 cdti
    Mar 2011
    Glasgow
    Default doing the clutch tommorow on 1.9 cdti
    m32 gearbox, anything i need to know in particular
    West
    Are you replacing the dmf & slave at the same time
    Mar 2011
    Glasgow
    yep dmf and slave being done with brand new gearbox oil and dot 4 brake fluid for slave
    not looking forward to it i tell you that now
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    You will need big torx sockets t55 or t60, can't remember for the flywheel bolts, remember to spray paint where the subframe was for aligning it back up.
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    the cluth is a bit of a pain to line up is all i can say so be prepared for neck and arm ache.
    Mar 2011
    Glasgow
    thanks guys i have one small problem
    how do i remove this peice (what is it even called) it appears to be connected to the slave cylinder
    Mar 2011
    Glasgow
    Got it off had to use grip pliers and twist it. Taken everything off except subframe and top gearbox mount so hppefully will get this done today
    Dec 2010
    Glasgow
    Mileage : Near 100K
    It should just be a clip that holds the csc hose in, been over a year since I did mine so I can't really remember.
    Mar 2011
    Glasgow
    you are right it was a clip pulled it off, what a nightmare
    have to say vauxhall designed the vectra "over-complicated" i wouldn't remove half the things that i did on other diesels like skodas/passats/etc.
    why are vauxhall design engineers thick as mince??
  1. mot tommorow
    By DAVIDD88 in forum General Chat
    Last Post: 14th November 2012, 09:53
  2. who is back to work tommorow
    By peadar in forum General Chat
    Last Post: 4th January 2011, 15:42
  3. HELP PLEASE!!! Mot tommorow!
    By mucklestone in forum Electrical & ICE (including SatNav)
    Last Post: 16th December 2010, 22:17
  4. going to get my vec C tommorow
    By glasgowrob in forum Vectra C / Signum Car Chat
    Last Post: 21st November 2009, 18:21
  5. New wheels tommorow
    By sri_joe in forum Styling
    Last Post: 5th September 2009, 17:23
