Thread: 2.2 direct.how do i remove and clean egr valve?
    Jun 2009
    Middlesex
    Default 2.2 direct.how do i remove and clean egr valve?
    Can i remove and clean the EGR Valve on my 2004 2.2 direct. I have been told it's a piston type valve and seems to be sticking.Got amber engine symbol light on dashboard?
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    yes but you will loose ya coolant aswell as its water cooled
    Dec 2011
    newport
    Trim : SXI
    Engine : 2.2 DTI
    Mileage : 105k
    if its the same as mine remove the engine cover egr is on inlet manifold remove 2xwater pipes you will lose a bit of coolant just make sure the header tank cap is on or it will pump out. one bolt on top of egr and one bolt underneath it. you may need to prise it away from the manifold. I have little knowledge of mechanics and i took it off cleaned it and refitted it in 20 minutes. however yours may be different to mine as mine is diesel
    Regular Member Paulwr's Avatar
    Mar 2012
    Ormskirk, Lancs
    Vehicle : Astra H 1.8 VVT
    Trim : SRi XP 3dr
    Engine : Z18XER
    Mileage : 12k
    Quote Originally Posted by Dobs View Post
    Sign up to http://www.z22se.co.uk/forum/ these guys have loads of info and knowledge on both the Z22SE and Z22YH engines.
    Aug 2011
    Bristol
    It is possible.
    It is on the right side towards the back of engine bay, behind fuel pump.
    It's only 3 screws (or 4) to remove but you will loose coolant so make sure you have the correct type ready to top back up.
    Not sure how to clean it though.
    Z22SE is great website as they are dedicated to SE/YH engine.
    Jun 2009
    Middlesex
    Thanks.Will check it out.
  1. Egr valve.can i clean & refit on a 2.2. Direct.
    By Dobs in forum Engine & Drivetrain
    Last Post: 16th September 2012, 23:28
  2. remove dpf for clean
    By Richard.roberts in forum Engine & Drivetrain
    Last Post: 5th January 2012, 22:42
  3. How to remove and clean EGR on dti engine.
    By macdad in forum Vectra C / Signum Car Chat
    Last Post: 31st October 2008, 22:52
vectra c 2.2 yh egr delete
zafira 2.2 petrol egr valve location
egr valve vectra c 2.2 direct
how to clean egr valve vectra c 2.2 dti
vectra c 2.2 egr valve clean
how to clean the egr valve on a vectra c 2004 2.2 sri
egr delete on 2.2 direct port vauxhall signum
vectra 2.2 direct egr valve
vectra c 2.2 egr valve location
vectra c 2.2 direct egr valve clean
egr delete opel vectra c 2.2
