Results 1 to 3 of 3
Thread: Kitchen Taps Query
    South east
    Default Kitchen Taps Query
    Does anyone know where I can get replacement handles for kitchen mixer taps as shown in the photo below? They're plastic with a chrome effect on them, which means the chrome wears off with use, and replacing the handles will mean I don't need to throw away what is other wise a very good set of taps. I've tried ebay, but no luck unfortunately.
    I've seen a few of these, all with the same wear and tear issue
    I would suggest you buy a cheap one from eBay UK, then remove the controls as they will most likely be damaged in the process
    You can the work out how to remove yours without damaging them, then arrange for them to be rechromed
    Sadly it is most likely that a replacement will be the only option; welcome to throw away Britain
    Dec 2011
    Seaham
    The chrome end covers will flick out with a small flat screwdriver and you should then see the screw that holds the tap hande in place. Take one with you to PLumb Centre or B&Q to see if you can get something that will fit.
  1. Kitchen
    By ed taylor in forum General Chat
    Last Post: 10th June 2012, 20:56
  2. Taps talk test
    By baz2003uk in forum Signature & Avatar Testing
    Last Post: 28th April 2012, 20:58
  3. Taps......... Again
    By Damian in forum General Chat
    Last Post: 14th June 2010, 22:47
  4. basin taps cp fitting and trap all new
    By barrymanalow87 in forum General items for sale
    Last Post: 9th March 2010, 00:17
