Results 1 to 10 of 16
Thread: seriously worried
    May 2012
    wirral
    Default seriously worried
    hi all , ive got 1.9 sri 150 cdti and last few days its been really struggling when i pull off upto about 2k revs then all power is normal especially in second gear its actually getting dangerous pulling out on some junctions as lack of power until hit about 2.5 k, tonight the car/spanner light is staying on and also the engine management light has now also come on permanently ,ive read a few posts and not sure if im looking at egr valve or inlet manifold ? ive checked the swirl rod and its still connected but i do have a build up of sludge/oil on the far right side of rod , i was thinking can i just disconnect the egr valve and see if it drives ok ?
    any replies appreciated
    Jul 2011
    UK
    Year : 06
    This sounds like a split vacuum hose or intercooler hose. At the front of the engine ul see some small thin hoses at the right of the engine near the battery next to radiator those are vacuum check the bends for splits. The intercooler one is the big thick one between the engine and battery
    Either that or u have a blocked Egr try cleaning it
    May 2012
    wirral
    Quote Originally Posted by marc vectra sri View Post
    thanks marc , i have changed those hoses about two months ago they are fine ive checked them yesterday , is there a way of knowing its egr blocked , ill just replace it rather than clean it if its that ?
    Jul 2011
    UK
    Year : 06
    Cleaning it is really easy just use carb cleaner saves buying a new one also ya boost sensor next to the Egr that could need a cleaning or u have a faulty maf
    May 2012
    wirral
    faulty maf ? whats that mate
    Jul 2011
    UK
    Year : 06
    It on ya airfilter hose I think
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Do you have any way of reading codes?
    what mileage has car done?
    possible faulty maf sensor.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Quote Originally Posted by mikecoz View Post
    Mass air flow meter.
    monitors the amount of air taken in. By measuring the resistance across a hot wire.
    The wore becomes gummed up over time so it affects the readings.
    it Can be confirmed by watching short and long term fuel trims along with maf readings at various rev ranges
    May 2012
    wirral
    Quote Originally Posted by Critch View Post
    just noticed your on the wirral , you work in a garage mate ? cheers for reply , im suprised the egr valve isnt first on everyones list
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    You can unplug EGR to try light will stay on though
  1. Someone please help im worried!
    By dannyjpuk in forum General Chat
    Last Post: 15th February 2011, 17:03
  2. Bit worried, might be over nothing!
    By george1987 in forum Engine & Drivetrain
    Last Post: 7th April 2010, 21:29
  3. Now i'm worried
    By braveheart in forum Vectra C / Signum Car Chat
    Last Post: 29th January 2010, 10:26
  4. Should i be worried?
    By Si-SRI in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2010, 22:41
  5. Bit worried
    By SRIRob in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2010, 20:03
