Thread: Central Locking Problem
    Nov 2012
    Essex
    Default Central Locking Problem
    Hello all,
    Hoping for some help with a central locking problem....
    Got home tonight, pressed the key-fob to lock the doors, they lock, but immediately unlock again. This little sequence goes on for a while (I lock, they unlock...) So I locked all the doors manually.
    Then I pressed the unlock button...nothing....pressed the lock button & they unlock.
    In summary the car keeps unlocking itself & pressing the lock button will actually unlock the doors.
    Any help gratefully received
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    One of the doors isn't shut properly or at least the car thinks its not.
    jump in close doors start car does interior light go out?
    do you have symbol on dash showing a door is open?
    chances are its the micro switch in drivers door lock. But it could be any of them.
    for time being open passenger door and manually push all locks down.
    thats will at least secure your car
    Nov 2012
    Essex
    Quote Originally Posted by Critch View Post
    Thanks for replying
    The interior light stays on if I start the car & drive. There's no warning on the dash though. How do I check the micro switch in the doors?
    I've managed to secure the car by pushing down 3 passenger door lock tabs & locking drivers door with the key
    Nov 2012
    Essex
    Well I've disconnected the electrical connector to the drivers door, reconnected it after counting to 10 & the central locking & key remote are both working fine again. Fingers crossed that's sorted it for good
  1. Central locking problem
    By Badger59 in forum Electrical & ICE (including SatNav)
    Last Post: 10th October 2012, 21:47
  2. 1.8i 16V T Reg Central Locking problem
    By Mytac in forum Electrical & ICE (including SatNav)
    Last Post: 31st December 2008, 10:12
  3. Central Locking problem
    By NKB in forum Vectra C / Signum Troubleshooting
    Last Post: 28th December 2007, 02:24
  4. Central locking problem
    By Hideous in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2007, 11:29
  5. Central Locking Problem
    By Penfold in forum Electrical & ICE (including SatNav)
    Last Post: 8th June 2007, 22:20
vectra c door lock warning sign on when starting
