Results 1 to 10 of 16
Thread: battery off to reset remap?
    Regular Member mrk's Avatar
    14:88 our time will come
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    Default battery off to reset remap?
    read on here about this as it appears to reset the remap to orig' remap settings,ie gets rid of "learned" settings.just wondered if this was advisable to do regularly to keep the map settings as the mapper set them.
    Vehicle : .
    Trim : .
    Engine : .
    Year : .
    That's not true fella. I've had the battery off for hours even a few days and the map is still there.
    Sent from my iPhone 5 using Forum Runner
    Trim : improving
    Year : 06
    i meant you get the origional REMAP back without learned behaviour,
    Vehicle : .
    Trim : .
    Engine : .
    Year : .
    Nar, still didn't happen to me. Map felt the same before and after battery removal.
    Maybe other members have experienced though, but not me.
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    A remap flashes the EPROM part of the ECU which holds the map data. When the battery is disconnected the static ram part if you like gets wiped. The static ram part is the bit that holds data which changes with time and driving style. This means anything the ECU has learned about driving style gets reset. The map has to be flashed off of the ECU to get deleted. That's the just of it anyway.
    Think of it as the BIOS chip in a PC, that doesn't lose data when the PC is switched off but all of the contents of the RAM are lost. The BIOS chip can be flashed though too as it's EPROM.
    Insignia VX-Line Nav CDTI 170.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    id heard that somewhere as well pulling the batt lead off reset the ecu to its prelearned state
    wirral
    33 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Removing will change batt any learnt values.
    But will not affect your remap
    Trim : improving
    Year : 06
    Quote Originally Posted by Critch View Post
    thats what i meant exactly m8 ,lose learned stuff not the map,so is it worth doing do we think
    Oct 2007
    Ripon
    How long do you have to leave the battery off to 'lose' the temp stored data?
    morecambe
    34 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    as said u will not loose the map promise
  1. battery wiring block next to battery 150tdci - HELP
    By jameslunt in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2012, 07:19
  2. Battery Light ON - 14.1 volts at battery
    By snapsnap in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2011, 13:55
  3. ?install remap after diconecting battery..
    By nikroc in forum Engine & Drivetrain
    Last Post: 28th June 2011, 17:17
  4. will disconnecting battery lose/reset my remap??
    By delberto in forum Diesel Engine related
    Last Post: 24th February 2011, 13:07
  5. disconnect battery after remap?
    By trucker in forum Tuning
    Last Post: 17th September 2006, 08:49
