Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Fume smell, smoke test??
  1. #11
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by Humourbash View Post
    I have the draper tap and die, so try rethreading to slightly larger size? Ok, what size bolts is it now and what size should i go for? To those who done it :-) i should oil as i tap?
    I re-threaded to the same size and used the existing bolts - can't remember the size off top of my head (have the kit in the garage still, so can check), the hardest part was drilling it out initially, there isn't much room behind there so ended up buying a 90 degree drill extension.
  2. #12
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Drilling it and rethread same size? I'll see what size it is once i finished wallpapering! Wife with baby gone out for the day (i kicked them out as wife keep getting in the way!!)
    I'll do it this week. Thanks for advice guys :-)
  3. #13
    Lancashire
    Trim : XP1
    Mileage : 66000
    Yes, you drill the existing threads out, tap it, then when the new threads are inserted you can use the existing bolts - I will check my kit tonight in the garage.
  4. #14
    Dec 2011
    Seaham
    I have some thread gauges in my tap and die set.
    I wouldnt drill out the old threads, use the existing threads as a guide and the tap should clean the exisiting threads and reset them.
  5. #15
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    I have the thread guide as well :-) will sort it once jobs done.
  6. #16
    Sep 2012
    portsmouth
    strangely enough that is exactly the same thing i was looking at on my sons Signum. The smoke is almost undetectable but shone a bright light in the direction of the flexible joint (what the hell is that for?) and exhaust was coming out the back joint. Some of the weave was coming away from the flange and there appears to be a hole/delve underneath?
  7. #17
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Flexi is needed to keep turbo intact in fitting place i believe. If it was stiff and vibrates. Could cause issue to turbo,
    Dont know tho...
    On other note, fumes smell could come from egr valve... As the threads are worn, thus not tight fitted mean leak around gaps...
    Will try fixing it if i havent had to taxi family members to destinations etc!!!
  8. #18
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    New bolts fitted, a lot better than the old ones i had, rethreading with tap was fine. So looked at bolts, it looked fine but was no good. New ones tight now.
    Found an slight wet patch ar injector area, the 2 nearest to battery seem wet. Slight spray like on top cover! So going to attend that tmw if my friend's free! Holiday friday so think it'll need seeing to dont it??
  1. Best/Quickest way to eliminate smoke smell in new car?
    By mpc in forum General Motoring Chat
    Last Post: 9th September 2012, 15:45
  2. Diesel fume smell at start up
    By lee gsi in forum Diesel Engine related
    Last Post: 5th December 2010, 17:30
  3. 1.9cdti black smoke/smell
    By dubsrus in forum Engine & Drivetrain
    Last Post: 16th November 2010, 17:58
  4. fume smell, hard bitumin around injector???
    By dth150 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 20:58
  5. help with fume smell in grande punto.....
    By bobby-tupper in forum The 'Off Topic' room
    Last Post: 22nd February 2010, 17:48
vectra c fume smell
