Results 1 to 10 of 18
Thread: Fume smell, smoke test??
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default Fume smell, smoke test??
    Hi all, not been active for a while, been busy fixing other people's cars and hospitals etc!
    Anyway, now i'm a bit slumped... Exhaust smell in cabin, been looking for answers on here but far too many to look, so little time.
    I've had a look under car today after fixing brake fluid leak at rear hub, took my chance to inspect for leaking fumes, flexi seems fine all joints/gaskets all hold seal, brought car back down, strong smell from bonnet whilest running idle,
    Is there any sort of test like smoke test where u can identify by colour of smoke leaving colour on area of leak??
    I will re try flexi with someone blocking rear exit box so i can try inspect flexi once more,
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Few things can cause this mate:
    Exhaust flexi.
    EGR gasket.
    Leaking swirl valves.
    May be a few others too
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Egr valve the threads are weak! Any thing i can use to seal it? While screws arent tightable!
    I tested flexi and all connections while engine idling for leaks. Dont feel anything apart from cooling fan blowing.
    Smoke test? How to do it and what to buy?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by Humourbash View Post
    New gasket and new bolts maybe? That could be your issue mate
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Quote Originally Posted by tony-1977 View Post
    Cant use bolts as threads inside hole is worn. Bolts are ok. I've used thread tape to see if it'll help, no luck. Cant afford time to replace manifold (top part)
    Only smell fumes when idling etc but dont smell it when driving.
    Gasket is new. Well, 3 months old. Always smell before new one tho.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    If you can work out if it is definitely coming from the EGR valve with the knackered bolts, you could always helicoil it, just be careful. If you're not confident a garage may be able to do it without taking the manifold off. Should only take half an hour.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Dec 2011
    Seaham
    Or simply try re-cutting the threads with a good tap, it is amazing what you can restore. Or tap out to a slightly larger bolt.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by cont1204 View Post
    Did this on previous CDTi, literally took about an hour all in, and makes them better\stronger than OEM.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    I have the draper tap and die, so try rethreading to slightly larger size? Ok, what size bolts is it now and what size should i go for? To those who done it :-) i should oil as i tap?
  1. Best/Quickest way to eliminate smoke smell in new car?
    By mpc in forum General Motoring Chat
    Last Post: 9th September 2012, 15:45
  2. Diesel fume smell at start up
    By lee gsi in forum Diesel Engine related
    Last Post: 5th December 2010, 17:30
  3. 1.9cdti black smoke/smell
    By dubsrus in forum Engine & Drivetrain
    Last Post: 16th November 2010, 17:58
  4. fume smell, hard bitumin around injector???
    By dth150 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 20:58
  5. help with fume smell in grande punto.....
    By bobby-tupper in forum The 'Off Topic' room
    Last Post: 22nd February 2010, 17:48
vectra c fume smell
