Thread: 2005 Z18XE EML code P0100, where to start 1st to cure? Any help appreciated.
    Regular Member Jow20's Avatar
    Sep 2010
    Leeds
    Default 2005 Z18XE EML code P0100, where to start 1st to cure? Any help appreciated.
    From what ive researched i believe it to be maf related, this has just come on from having a full service and new thermostat and coolant temp sensor and fuel filter. Maybe it disturbed something??? If the mafs are sensitive.
    so to nail the problem, would you 1st clean the maf with pure alcohol spray? Could it be possible 02/lambda sensor too?
    throttle body needing a clean also maybe?
    where would you start as i carnt really afford a garage and want to sort myself if i can. Can you confirm if that code would be caused by anything else? Thanks folks.
    wirral
    56 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    I would start with viewing actual data and go from their.
    You could test maf with a multimeter
    Sep 2010
    Leeds
    I dont have multi meters etc...
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    You maybe able to do the pedal test and that will help narrow down the fault. Have a look through the how 2s to see how its done.
  1. PLEASE HELP ERROR CODE p0100
    By signum_05 in forum Vectra C / Signum Troubleshooting
    Last Post: 20th December 2012, 20:20
  2. vectra c 2005 1.8 Z18XE
    By Tropax in forum Engine & Drivetrain
    Last Post: 24th February 2012, 21:05
  3. Fault Code P0100
    By dhwigston in forum Engine & Drivetrain
    Last Post: 1st August 2011, 06:46
  4. Fault code P0100, AGAIN!!!
    Last Post: 1st June 2010, 14:20
  5. Fault Code P0100
    By vectra2004 in forum Vectra C / Signum Troubleshooting
    Last Post: 27th May 2008, 19:08
z18xe p0100
p0100 vectra c z18xevectra c 1.8 p0100corsa c z18xe p0100p0100 vectra 2005vectra c z18xe p0100
