Results 1 to 10 of 15
Thread: need some help guys
    Nov 2012
    northwest
    Default need some help guys
    hi all
    ok, took the car out before (vect c 1.9cdti 16v), lost all power after 2500rpm, no turbo nothing. had to restart the car and all was ok for 2 mins then same problem again, at the same time i noticed the thermostat had started working again, its not worked for 6 mnth so i thought it must be linked to the turbo problem.
    just had the AA out and the fault codes are as follows
    p2279 plus - intake air leak
    p0105 - map sensor
    any of you guys experienced these problems and if so how do ya fix it
    cheers all your help is welcomed
    Nov 2012
    northwest
    btw the 1st code had the plus at the side of it which the AA told me was the fault that was causing the problem
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 132000
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 132000
    Hose leak from MAF to turbo
    4) Turbo problems - including vacuum hoses
    5) Hose leak from turbo to intercooler
    check for splits in the intake hoses - the ones either side of the intercooler are prone as is the intercooler itself, but you would usually hear a whistling.
    Nov 2012
    northwest
    cheers pal, dont know if this might be the cause but i removed the small filter from the little box to the front right if engine, the one with the 2 pipes coming out of it, funny it just decided to do it now thou, ive been doing 300 miles a week since xmas without a problem
    Nov 2012
    northwest
    whats the best way to check for leaks?
    washing up liquid and water on the hoses?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 132000
    also clean egr valve
    Nov 2012
    northwest
    link not found pal but the egr was cleaned and then blanked off
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 132000
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 132000
    Quote Originally Posted by faz123 View Post
    i just found that out lol
  1. Thanks Guys :)
    By nicky in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2011, 09:11
  2. What do you guys think?
    By CraigoT in forum Styling
    Last Post: 26th August 2011, 23:01
  3. Help please guys!!!!!!
    By srinav in forum Engine & Drivetrain
    Last Post: 13th August 2011, 10:17
  4. Bit of help please guys
    By Lump in forum Suspension, Wheels & Brakes
    Last Post: 18th April 2009, 16:35
  5. Hi guys
    By yessof in forum Introduce yourself.
    Last Post: 1st February 2009, 21:08
