Results 1 to 4 of 4
Thread: LED side lights BUT using a relay?
Hybrid View
    Mar 2010
    Trim : Design
    Engine : 1.9 CDTi
    Default LED side lights BUT using a relay?
    Has anyone fitted led side lights but used a relay?
    Ie: Pull out the normal sidelight holders and bulbs, and splice the power from the live to a relay so it triggers the relay, then take the power for the relay from the battery?
    Regular Member ScotsDragon's Avatar
    Aug 2009
    Lost in Time and Space...
    Trim : SRI
    Engine : 1.9 CDTI 150
    Mileage : 50000
    Thats similar to what i have done with my angel halos, you still need something on side light circuit for bulb test ie resistor
    Mar 2010
    Trim : Design
    Engine : 1.9 CDTi
    Was just going to run 2 under bonnet lights and use the side light 'bulbs' (Lengthen the wires to 2 new under bonnet lights using the same wattage bulb) so they are still 'in circuit' but doing a different job.
    Hanging Heaton
    35 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    It's easier to just fit seperate under bonnet lights, then just seperate holders for the side lights (tuck the old away)
    Only really need a relay if the trigger is too weak to power the bulbs for example, otherwise you'll just be adding extra things for nothing...
  1. side lights and number plate lights
    By antowens in forum Electrical & ICE (including SatNav)
    Last Post: 13th September 2012, 19:59
  2. Led Side Lights Fitted & 2 Rear Fog Lights
    By wardy23 in forum Electrical & ICE (including SatNav)
    Last Post: 12th March 2012, 23:16
  3. led dash lights and side light running lights
    By fjaimo10 in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2012, 21:21
  4. Brighter Lights for side lights, Vectra SRI150
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2011, 23:50
  5. Philips bluevision h7 head lights & side lights brand new
    By davidlewis24 in forum Parts for sale
    Last Post: 19th March 2009, 22:42
