Results 1 to 10 of 14
Thread: Wipers popped off the push rod
    Sodding Typical on Sea
    Default Wipers popped off the push rod
    Total Nightmare tonight on the M77 about 15 miles from home the wiper popped off the main push rod and left me in hurricane force rain to get home!
    Is there a short term fix for this problem I can't seem to find any how2's as I will order a new pair of the rods in the morning!
    Typical I am needing the car more than every this week!!!
    However this really is my first major issue in 2 1/4 years so I can't say I am upset with the car
    Derek
    11 Post(s)
    Quote Originally Posted by Derek Mc View Post
    In the HOW2 for fitting a new linkage, there is a picture showing a temp repair using some cable ties.
    EDIT - This one
    Jul 2011
    Leeds
    Vehicle : Insignia 160
    Trim : Elite Leather Light n Sight
    Engine : 2.0 16v
    Year : 2012
    Mileage : 50k
    You dont even need to take the wipers off.
    You can get in under the scuttle,after removing the rubber strip.
    One of mine went last year,fixed with 2 cable ties and the other one went last month,again,fixed with cable ties.
    Its usually the underneath cup which wears out due to gravity.
    You can even buy speacial clips to repair this badly designed linkage.
    Some folk on here have used cable ties and they are still holding years down the line !
    Good luck with it. Five minute fix max !
    Thank you!! I will effect the cable tie fix today
    Nov 2012
    Norfolk
    Vehicle : BMW
    Trim : 320D
    Engine : .
    Cable ties wouldnt work on mine, both sides went at once so when I cable tied one side, it pulled the other off & vice versa
    Regular Member Mr Owens's Avatar
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    I tried the cable tie quick fix and at 70mph they decided to let go and I had wipers bouncing all over the place. I bought the new rods off eBay and they've been fine (touches wood)
    I have ordered new push rods from Wipex Ltd so should get round the problem long term. £35.90 delivered for the pair. more expensive than cable ties but hopefully a longer term option
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 135000
    same happened to me the left wiper gave up so i decided to buy a new wiper linkage 90 pounds from vauxhall its a common fault on the vectra c
    or as you have done you can buy the rods
    morecambe
    42 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    i used tie wraps lasted two years lol on the siggy
    I went to Wipex ltd., cost me £35.40 delivered for new push rods, I finally twigged how to remove the scuttle so was able to get the old rods off and replacements snapped into place greased the cups before snapping them home, re-assembled job done. 30 minutes tops and they were perfect.
    No more slapping into the a post
  1. driveshaft popped out
    By Swedge in forum Engine & Drivetrain
    Last Post: 9th September 2012, 15:19
  2. Just popped in.....
    By spoons in forum General Chat
    Last Post: 30th September 2008, 11:31
  3. Just popped in.
    By barney in forum General Chat
    Last Post: 12th March 2007, 12:46
  4. E/M - popped our cherries
    By JCB in forum 2005
    Last Post: 1st August 2005, 08:34
opel astra 2007 driveshaft popped out
