Results 1 to 10 of 17
Thread: Vacuum Pipes. 1.9 120. 2004 vectra c
    Nov 2012
    Derby
    Vehicle : Vectra 1.9 CDTI 120
    Trim : Energy
    Engine : 1.9 8v 120 BHP
    Mileage : 170, 000
    Default Vacuum Pipes. 1.9 120. 2004 vectra c
    I have been having intermittent probs regarding poor power especially when on an open road, it seems to take an age to reach 70mph and as for overtaking forget it.
    I have tried all the How 2's regarding EGR/MAF/MAP/BOOST PIPES/TURBO BOOST SOLONOID/AIR FILTER/FUEL FILTER. All to no avail. Not getting any codes either.
    My question is I am unable to check vac pipes that go round back of engine into reservoir. On some 120's I have seen pics of these pipes go straight to the turbo boost solonoid on the slam panel. Would I be able to bypass the vac reservoir and simply join them up ?.
    I use Torque pro on my android and the vac reading at idle is 31.5 if this helps.
    Jul 2011
    UK
    Year : 06
    Vac pipe is on the front in the middle of the engine next to the radiator mate
    Nov 2012
    Derby
    Trim : Energy
    Mileage : 170, 000
    Yes I know but it goes to the reseviour at the back of the engine first. I want to know if I can bypass the reseviour incase I have a leak in the pipes close to it where I cant reach. Cheers anyway.
    Jan 2012
    Silverstone village
    Ah so that's what it goes to behind the engine , always wondered.
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Quote Originally Posted by carling View Post
    Pul the MAF sensor plug out and run it see if there's a difference.
    If still the same
    Get the codes read on Tech 2 or Vaux-com if your using a generic reader.
    Nov 2012
    Derby
    Trim : Energy
    Mileage : 170, 000
    Thanks for the reply will try that. Although wouldnt that throw up codes anyway ? With it being unplugged ??
    Nov 2012
    Derby
    Trim : Energy
    Mileage : 170, 000
    Anyone any idea if I can bypass the vacuum reservoir ?
    Nov 2012
    Derby
    Trim : Energy
    Mileage : 170, 000
    Anyone ?
    Nov 2012
    Derby
    Trim : Energy
    Mileage : 170, 000
    Bit of an update
    Bypassed vac reservoir as described above. Still sluggish
    Unplugged MAF. Would hardly move so plugged back in so thats ok.
    Unplugged boost control sensor. Even less power so plugged back in so thats ok.
    Took it for a run and thrashed it in 3rd, spanner light and into limp mode.
    Got codes read = PO234
    Although the boost control sensor (MAP) works can it break down under revs ? Or if it was faulty would it not work at all ?.
    May 2011
    South London
    Check the turbo solenoids free to move and isn't stuck, its about 10mm movement, don't adjust it either.
  1. vacuum pipes from pump
    By james walker in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2011, 22:00
  2. P 0100 on vectra dti is back but my vacuum pipes intact!
    By yogishniz in forum Troubleshooting
    Last Post: 12th July 2011, 10:37
  3. Do vacuum/boost pipes have to be a certain length
    By tommytonguedj in forum Engine & Drivetrain
    Last Post: 27th May 2011, 17:05
  4. Another post about Vacuum Pipes!
    By lostdog in forum Diesel Engine related
    Last Post: 30th March 2011, 11:35
  5. Vacuum Pipes on Diesel engines
    By Niks in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2009, 20:05
vectra c vacuum pipes 8v
vacuum reservoir vectra c
