Thread: rad mounts
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default rad mounts
    Need pointing in the right direction. I going to replace the rad mounts because I've done arb bushes and droplinks but still get creaky sound. but could you tell me how many mounts there are. any info on how to replace them will be a big help
    Administrator plasma's Avatar
    On the Forum
    357 Post(s)
    Engine : 150
    Mileage : 74000
    there are two rad mounts. To get to them you have to lower the radpack down by undoing two torx bolts which are accessible underneath the car, (may need underbelly tray off), as you undo these you'll see the rad pack start to drop. from inside the engine bay you should be able to pull the radpack towards you to get access to the mounts, the mounts are rubber V shaped bits which sit into an upside down V shaped receptacle.
    Oct 2009
    Sandwell
    ordered some new ones today are these the right ones part no, 013140216 x 2 and 090091989 x 2
    Oct 2009
    Sandwell
    just searched on here and found part number 13186475 for mounts. have i ordered wrong parts?
    also anybody got a pic of the rad area of were there located?
  1. Top mounts
    By RBH in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2012, 07:49
  2. rad mounts help
    By n8sby in forum Suspension, Wheels & Brakes
    Last Post: 16th March 2011, 10:21
  3. Top mounts??
    By LEW1S2006 in forum Suspension, Wheels & Brakes
    Last Post: 9th December 2009, 17:51
  4. rad mounts
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2008, 13:42
