Thread: Fuel Gauge
    Jul 2011
    Daventry
    Default Fuel Gauge
    Hi
    Filled up my CDTI 150 this morning to the Brimm and set off on an 80 mile drive, the fuel gauge went 5mm past the full mark (further than ever before) and has stayed there since, the range reading on the centre console is showing 860 miles (i wish).
    The needle responds to power off e.g zero`s with ignition off but returns to position way past full with ignition on, despite having driven 80 miles this morning.
    Can anyone help please - sender problem?
    Many Thanks
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Give it time.... mine's done that many times... seems to be using nothing and then suddenly you'll 'use' a quarter tank just popping to the shops 5 minutes away.
    Jul 2011
    Daventry
    Thanks for the response
    I am more concerned about the fact that the needle in the `full` position has gone a good bit further round than in the past, normally it just rests slightly past the full mark but this is 5-6mm past this line
    Jan 2012
    Silverstone village
    I'm guessing the float in the tank may be stuck , sure continued usage as the fuel drops it should work its way loose.
    Dec 2011
    Seaham
    Fuel gauges are terribly inaccurate at best of times. I had a Reliant Scimitar that would use half a 20 gallon tank in the first 150 miles, then get 350 miles from the second half tank.
    Regular Member Beardy's Avatar
    Oct 2012
    Thetford
    Vehicle : Astra
    Engine : 1.7 CDTI
    Mileage : 110,000
    Quote Originally Posted by Handyandy-UK View Post
    my siggy done this the other day, was showing 88 miles range then about 5 miles of driving it jumped down too 50 miles range!!
    Dec 2011
    Seaham
    That could be down to a few things? I beleive the range is held over from the previous drive, hence if you start the car from cold, the range will drop significantly, or if you have suddenly become a bit heavier footed.....
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    .... or someone's been nicking your fuel lol
  1. Fuel Gauge
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2013, 09:40
  2. Fuel Gauge
    By don23 in forum Vectra C / Signum Car Chat
    Last Post: 26th May 2011, 23:09
  3. rev counter/speedo/temp gauge/fuel gauge stopped working
    By bloodworm in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2009, 00:28
  4. fuel gauge
    By lob1954 in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2009, 19:36
  5. Replies: 2
    Last Post: 15th September 2008, 23:18
