Results 1 to 10 of 11
Thread: can both rear calipers seize at same time?
    May 2012
    northwest
    Vehicle : signum
    Trim : elite
    Engine : 3200
    Default can both rear calipers seize at same time?
    I have posted a brake issue before but was wondering if anyone could help me on this
    I had problems with the rear brakes sticking a while back when we had some cold weather well i decided to have another look today so i jacked the rear up and checked both wheels and they were spinning freely but as soon as i touched the brake pedal they locked on and i could hardly turn either wheel.
    So i removed offside rear wheel and removed the caliper it looks a bit rusty so i cleaned it up and then had a go at winding the piston in (i dont have correct tool) with some pliers and as hard as i tried it just wont budge so the question is are the calipers seized and how likely is it both went at the same time .
    I have driven around withe the handbrake cable disconnected for a bit because i thought that was the issue but it didnt make much difference
    so the main question is can you turn the piston with pliers or do i need to buy correct tool and if you cant turn the piston does this mean caliper is seized
    sorry for the waffling
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    I'd try with the right wind back tool first, but yes its very possible that both rear calipers can seize at the same time.
    Full Member vmb2722's Avatar
    May 2012
    Blackpool/St Mary's Bay
    Trim : Exclusiv
    Engine : 1.9 CDTi 150
    be sure to remove the cap on the brake master cylinder resevoir before u wind the pistons as this will decrease resistance but be carefull because u may lose brake fluid. the caliper pistons always benefit by a clean with brake fluid and an abrasive cloth, if they wont budge you can remove the calipers and gripping them in a vice you can gently persuade them with a variable pressure applicator and a brass drift!
    May 2012
    northwest
    Vehicle : signum
    Trim : elite
    Engine : 3200
    I have several of those variable pressure thingys
    I have to say its hard to get a good grip on the pliers with the caliper loose so i might remove it first thing and get it in the vice
    If i need to replace both calipers whats the cheapest route to go down I'm going to sell car shortly so dont want to spend much on it
    Are signum rear calipers the same as vectras and is it worth going down the breakers route
    Dec 2010
    Glasgow
    Mileage : Near 100K
    Get new ones off ebay.
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    I got a new one from vx £66 and my old one.
    May 2012
    northwest
    Vehicle : signum
    Trim : elite
    Engine : 3200
    £66 was that recently i priced up on ecp and they were coming to £86 with exchange
    May 2012
    northwest
    Vehicle : signum
    Trim : elite
    Engine : 3200
    just now checked ecp and they are doing 25% off so they come to £130 are surcharge
    should i replace the pads aswell dont really want to spend much on car as its not worth much
    May 2012
    northwest
    Vehicle : signum
    Trim : elite
    Engine : 3200
    right a quick update i had a nightmare trying to get piston to wind in only worked when i clamped the brake line and disconnected the brake line and handbrake
    I think the issue is with the handbrake mech rather than the calipers as once i had loosened up the handbrake mech with a persuader it has done the trick
    So for the meantime i had disconnected the handbrake alltogether and I'm back to fast signum rather than something holding me back signum
    May 2012
    Trim : Exclusiv
    persuader/variable pressure applicator mans best friend
  1. rear calipers
    By ant6566 in forum Handling & Braking
    Last Post: 18th September 2012, 20:20
  2. For Sale: 292 rear calipers
    By plasma in forum Parts for sale
    Last Post: 25th November 2011, 20:23
  3. can Scottish police seize a vehicle?
    By Big Knox in forum Insurance Chat
    Last Post: 5th February 2011, 06:22
  4. VXR rear calipers?
    By Dose in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2010, 13:41
