Thread: water in clutch.
    Jan 2012
    Silverstone village
    Default water in clutch.
    Hi all
    I'm posting this in behalf of my farther, He has a 2005 1.7 cdti astra, and was going to see my ill grandmother.
    Anyway he ended up driving through some fairly deep water , knee high when stood outside the car.
    The car stalled when the water got so high. He managed to push it out and get it running again, drove home 30 miles , next day car will start in neutral but won't go into gear, start it in gear with the clutch depressed and it start to move the car.
    Anyone have any ideas ? , im assuming a new clutch ?
    Regular Member vmb2722's Avatar
    May 2012
    Blackpool/St Mary's Bay
    Trim : Exclusiv
    Engine : 1.9 CDTi 150
    cluch release bearing i reckon!
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    is the pedal harder than normal?
    Jan 2012
    Silverstone village
    The pedal feels normal, so im told.
    Thanks for the replies, assume worth while getting a new dmf if the clutch is done ?
    Dec 2010
    Glasgow
    Mileage : Near 100K
    Friction plate will be stuck to the flywheel, could try starting it in gear but with the clutch depressed ( it will want to drive off/stall etc)
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    Quote Originally Posted by XPCobra View Post
    sounds about right to me as well ,the last car I did with the same problem I started it in first , drove it down the road & managed some clever footwork to press all 3 pedals at the same time , sharp cracked it loose & was fine after that .
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Stick it in 2nd and start the car to get it going, then depress the clutch and see if you can sharply get the revs to rise. Hopefully the little jolt should free up the plate from the flywheel and return to normal.
    I would maybe go through all the gears on a 20 min drive to make sure the plate and flywheel is clear of whatever is still there tthat caused it to stick in the firstplace.
    Jan 2012
    Silverstone village
    Cheers guys , will have to get the old man to give that a go.
    Jan 2012
    Silverstone village
    Thanks guys he got it working in the end jacked up the front of the car got the engine running in gear , had the wheels free wheeling then slammed the brakes on while the clutch was depressed, took three attempts but all working now although time will tell if any permanent damage had been done.
    Dec 2010
    Glasgow
    Mileage : Near 100K
    Not a problem
    normal clutch use should clean the flywheel and clutch up anyway
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  3. What colour is your radiator water bottle water? and head gasket.
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2011, 21:39
  4. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
vectra clutch not working after driving through water
vectra driving through water
