Thread: Roof rail help needed please
    liverpool
    Default Roof rail help needed please
    Trying to sort leak in my boot. Aerial replaced but still leaking. Want to check the rivet that sits under rail in roof. Have opened x2 flaps in rail and loosened clips but still fastened securely at boot end. How is this removed? Thanks
    Regular Member farley2708's Avatar
    antrim n.ireland
    should just clip off mate start at the boot end then work towards the windscreen
    liverpool
    Quote Originally Posted by farley2708 View Post
    Is it just same clip that runs along rail, on inside of rail.
    antrim n.ireland
    as far as i can remember there are 4 on each side (n/s & o/s)
    liverpool
    There are inch long clips which I have pulled out from roof lifting the rail but I could not detach the very end by boot.
    antrim n.ireland
    if you need a couple PM me your address & i'll send them to you
  1. Roof rail rivet
    By daddy5times in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2013, 23:27
  2. How to remove roof rail?
    By eve01rton in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2013, 23:07
  3. Help needed - roof rack sizes.
    By tlc.left in forum Vectra C / Signum Car Chat
    Last Post: 25th May 2012, 17:47
  4. Vauxhall Roof Bars-Instructions needed
    By purple170503 in forum Vectra C / Signum Car Chat
    Last Post: 1st March 2010, 14:07
