Thread: 1.9 CDTI 150 Glow plugs....Help???
    Feb 2011
    Oxon
    Default 1.9 CDTI 150 Glow plugs....Help???
    Hello all
    I'm trying to change my glow plugs on my 1.9 Sri 150. They all unscrew fine and none of the threads have seized. However, they all seem to be stuck in the cylinder head somehow.
    They'll turn ok with the socket on, but make a squeaking noise (as if the shaft is a very tight fit in the hole) and don't come out any further - just spin in the hole.
    Any ideas why this is and how I would get them out. I'm very concious of the consequences of snapping one so don't want to be too brutal
    Any ideas will be very much appreciated..
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Carbon build up.
    bit of wd40 keep turning and spraying.
    and gently wiggle should come eventually
    Engine : 1.9 CDTi
    That will be a ring of carbon stopping them coming out.
    Seen people spray plus gas etc with them removed as far as they can so it breaks it down.
    Feb 2011
    Oxon
    Brilliant. Thanks for the advice. I'll give the plus gas a go tomorrow as that's what I have, and report back how it goes.
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    126 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    usually they come out if you try to start the engine
    seriously... a colleague of mine snapped one off (the threaded section came out but no further. not sure how he managed to snap it from there). he drove it for for a few days and eventually it popped out.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    The ends of the glow plugs can swell up and can stop them coming out. Use plus gas and twist them out using the thread in the head to help.
    As I mentioned in other threads these should really be part of the service and changed every 2 years to prevent issues when removing them
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by littleteapot View Post
    They do not "pop" out, they can come out with enough force to punch a hole through your bonnet. DO NOT use this method to get them out unless you want to cause damage
    woodbridge, suffolk
    126 Post(s)
    Trim : Design+
    Mileage : 101000
    Yes, probably not a good idea really. I was suprised my colleague didn't do any damage when his 'popped' out.
    Feb 2011
    Oxon
    Success!!!
    Thanks for the advice chaps. It took a lot of wrist action, unscrewing and screwing back in again to work the PlusGas through but eventually they came out intact. And I can proudly tell the missus that 30-odd years of "wrist strengthening excercise" has paid off!
    Just need to purchase a 1/4" drive 9mm deep socket now to tackle No.2 plug. My 3/8" drive fouls on the vaccuum (I think) hose to the high pressure fuel rail.
    Thanks again everyone. This forum is a brilliant resource to have. My car has cost me a fair bit of money in past couple of years but I must have saved treble that amount in being able to do the majority of the work myself, and that is down to the sound advice given by people on here.
    Long may it continue.
  1. 1.9 CDTI 150 glow plugs - DIY or garage?
    By klesniks in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2012, 13:23
  2. 1.9 cdti 120 glow plugs
    By big rich in forum Engine & Drivetrain
    Last Post: 10th September 2010, 13:46
  3. Change Glow Plugs on 120 CDTI
    By RS_Turbo in forum Vectra C / Signum Car Chat
    Last Post: 9th November 2009, 09:28
  4. Glow plugs on a CDTI 120
    By sthomson1 in forum Engine & Drivetrain
    Last Post: 5th November 2009, 22:39
  5. Glow plugs 1.9 cdti 120
    By mark230678 in forum Parts for sale
    Last Post: 3rd July 2009, 21:40
glow plugs vectra 1.9 cdti
how to fit vectra glow plugs
how to change glow plugs vauxhall vectra 1.9 cdti
how to change glow plugs on vauxhall zafira 1.9 cdti
vectra c carbon build up on glow plugs
how to change glow plugs on vauxhall vectra 1.9cdti
vectra c glow plug stck end
vectra 1.9 cdti glow plug
vectra glow plug stuck
vectra cdti 150 bosch glow plugs
how hard is it to change glow plugs on a vectra cdti 16v
glow plugs soaked in oil vauxhall
1.9 cdti 120 glow plugs same as 150
vectra c cdti glow plug tight to come out
vectra cdti 150 fitting glowplugs
how to change glow plugs on a vauxhall vectra cdti
vectra cdti glow plug change
vauxhall cdti 1.9 150 seized glow plug
vauxhall vectra 1.9 cdti glow plugs
how to change 1.9 cdti glow plugs
glow plugs wet and oil vauxhall signum 1.9 cdti 150
1.9 cdti glow plug change
how to change glow plugs vectra 1.9cdti
can glow plugs cause lag vectra cdti 150
where to locate glow plugs on vauxhall vectra
