Results 1 to 10 of 20
Thread: Newbie from Rochdale [2002 Vectra C DTI LS 2Ltr
    Jan 2013
    Rochdale
    confused Newbie from Rochdale [2002 Vectra C DTI LS 2Ltr
    Hello All
    Got car last week all seems ok so far,temperature gauge not working tested connector at engine 10 volts at the connector shorted connector with wire but gauge needle did not move, both fans come on when I unplug the sensor,has any one got any ideas,
    Thanks in advance
    wirral
    26 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    You got 10 volts on coolant temp sensor wire??
    Jan 2013
    Rochdale
    Quote Originally Posted by Critch View Post
    Yes
    VIP-Member Woody's Avatar
    May 2012
    North West (Warrington)
    109 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto LPG Converted
    Trim : Gsi with lots of "Extras"
    Engine : 3.2 Z32SE
    Mileage : 117,000
    Welcome aboard matey, hope you get your temperature guage sorted fella
    wirral
    26 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Are you sure you testing correct plug?
    Cts should be a 5v reference
    should get pulled closer to ground the hotter the engine gets
    Jan 2013
    Rochdale
    Default Low temp
    Yes its the connector from the temp gauge that plugs into the sensor the sensor on the cylinder head,I thought it would read 12 volts but reads 10 with digital meter,I shorted the connector to check whether the temp gauge would rise but it didnt.
    Full Member andy.l's Avatar
    Wirral / ellesmere port
    8 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    welcome aboard m8
    pretty local to me,im over in waterfoot
    2011 insignia elite tourer 2.0 cdti 160 manual,silver
    Jan 2013
    Rochdale
    Quote Originally Posted by woodpeck View Post
    Thanks Woodpeck
    wirral
    26 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    It's a thermistor running on 5v reference circuit.
    its a ntc sensor.
    so a cold engine would be 4.5v and slowly as temp increases go to 0.5-1v on hot engine.
    if you have 10v on the wire. Where are you grounding your multimeter?
    You possibly have a short to positive wire.
    What voltage do you have with sensor plugged in and testing via back probing using a paper clip?
    Jan 2013
    Rochdale
    Quote Originally Posted by andy.l View Post
    welcome aboard m8
    Thanks Andy.l
  1. Newbie from Rochdale
    By veccyDaz in forum Introduce yourself.
    Last Post: 27th May 2012, 00:07
  2. Vectra GL Plus 2ltr dsl 1998
    By curleyder in forum Electrical & ICE (including SatNav)
    Last Post: 30th March 2012, 14:27
  3. Vectra C 2002 Y20DTH Remap DTI 2.0 2002
    By richardkay007 in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2012, 14:18
  4. saab 93ss 2ltr t & 2ltr T wots the difference???
    By markspark in forum Engine & Drivetrain
    Last Post: 27th June 2010, 14:47
vectra dti remap rochdale
