Thread: Automatic gearbox, recommended?
    Regular Member astradriver's Avatar
    Dec 2011
    Slovakia
    Default Automatic gearbox, recommended?
    Hi Everyone,
    I'm looking at trading in my current Vectra C MY 2006 which I had from new for a very tidy low milage Vectra C MY 2008 with automatic gearbox. I specifically want a car with auto box. The car seems to have solid service history confirmed by dealer that serviced it.
    I searched the forum and found several guys that had issues with automatic, though as with everything people usually post when they have issues. I was wondering what is the experience of the people that didn't have issues. Does it drive smooth, does it react quickly on kickdown, that sort of thing?
    Both cars have same engine (1.9 cdti 150) in them, only my is gts the one I'm looking to buy is estate.
    Thanks.
    Aug 2010
    Leeds
    Not specific to the vectra but oil changes are the common problems with a auto box or the lack of them.
    A good oil and filter change every 30-40k will see the box work efficently it's life, rather than leave the oil in there for 70k when the problems start, so do make sure the oil has been changed on what you buy.
    Regular Member renodci's Avatar
    Kent
    Mine's a 3.0cdti auto, so not sure if it's the same gearbox as the 1.9. I would rate it very highly; kickdown is good, changing up at low revs when the engine isn't under load is good and all changes are smooth. The only criticism I have is that I've had cars with better tiptronic function (the computer won't allow it to change up when I want it to). Fortunately, because it's so good when left in 'D' that's little disadvantage. All of which is no use to you if it isn't the same gearbox as in the 1.9!
    Dec 2011
    Slovakia
    Quote Originally Posted by renodci View Post
    Actually it's the same box (AF40-6). Thanks for responding!
    Dec 2011
    Slovakia
    Quote Originally Posted by Bigtee View Post
    Agreed, I change the gearbox oil regularly in my current (manual car) too. Besides, according Opel/Vauxhall service plan where I live you're supposed to change the gearbox oil in automatic gearbox every 4 years/60t KM or every 6 years/80t KM, depending on the type of gearbox you have.
    Kent
    As far as I know, my gearbox oil has never been changed. I thought I read somewhere on here that if the gearbox is working fine, it's best to leave it alone.
    Jan 2008
    ipswich
    I renodci i had a 1.9 i had her autobox changed it made a lot of diffrence the 3.0 i got now is smooth as heck thats the only disavantage is that you cant change the gear up to 5 quick on as my old 6 speed 1.9 auto
    6 Post(s)
    That's what my local Vx garage keep telling me year after year when I book in for servicing. They are not one for turning down work given the oportunity either. They say there is no recommended mileage/year interval for the autobox oil to be changed.
    My 2.2 Direct auto now has now done 83,000 miles. The oil in the autobox has never been changed, and touch wood is as smooth as the day I bought it 5½ ago with 20,000 miles on the clock.
    Dec 2011
    Slovakia
    As I said in one of my earlier posts - where I live the interval for oil change in VeC automatic gearbox is 4 years / 60k kilometers (37 500 miles) or 6 years / 80k kilometers (50 000 miles) depending on the type of gearbox. As far as I know most manufacturers include automatic gearboxes oil change in the intervals, it's ceratinly the case over here.
    I'm not so sure about the "if it works leave it alone" approach. It's a complex mechanical device with a lot of precision parts and lot of friction between them. The oil in it isn't designed to last forever, you change your engine oil regularly as well, you don't wait for issues. When you start noticing something going wrong it's usually too late.
    6 Post(s)
    Quote Originally Posted by astradriver View Post
    Engine oil gets far more easily contaminated by the combustion cycle though. That said, modern engine oils are manufactured to make service intervals less frequent.
  1. gearbox automatic info
    By matt180 in forum Engine & Drivetrain
    Last Post: 30th September 2011, 13:47
  2. Automatic Gearbox
    By delboy2028 in forum Engine & Drivetrain
    Last Post: 1st March 2011, 16:28
  3. recommended Gearbox specialist
    By bret.c in forum Vectra C / Signum Car Chat
    Last Post: 16th October 2010, 23:09
  4. Signum 2.2 dti automatic gearbox
    By apacheenzo in forum Engine & Drivetrain
    Last Post: 2nd April 2010, 21:06
  5. HELP! Automatic gearbox problems
    By dracunciliasis in forum Engine & Drivetrain
    Last Post: 14th May 2007, 21:48
opel vectra 2.2 direct automatic gearbox oil change
astra mark 4 auto gearbox oil change
