Thread: Non starting Vectra 1.8Ls
    Jan 2013
    Loughton, essex
    Default Non starting Vectra 1.8Ls
    i own a 2002 1.8 16v Ls
    every now and again it wont start, its like the starter motor has packed up and a car with a spanner thru it flashes on the display ive tried turning ignition on and off locking doors and unlocking ect but to no avail it still wont start its not attempting to turn over theres just nothing bar a clicking coming from the fuse box on side of dash (passenger side)
    all of a sudden then it will start and the spanner light goes out after a few seconds of flashing any ideas ? the non starting bit normally accurs after i start it up it revs then imeadiatly cuts out after that then i have the issue with not starting and the spanner light flashing.
    The above paragraph was borrowed from another member, because my daughters car has the same symptoms. I hope he don`t mind, I tried to contact him but the post was nearly a year old and received no reply.
    The difference is it may start first time(revs then dies) or sometimes may take over a hour to start, constantly turning the ignition on and off. When it does start the car runs perfectly, when it`s switched off after being used, she has to go through the process again. Recently I had a diagnostic done by a friend, it showed up a dodgy crank sensor, so I had it replaced with a new one along with a camshaft sensor. It also has had new key, bought and programmed by Vauxhall. the new parts didn`t cure the problem, it was then put back on the diagnostic thingy, it cured the crank sensor code fault problem. Then a P0170 code keeps showing on the diagnostic.
    I`ve spent £170 quid already on parts, and I don`t really want to go down that path where i`ll change one part at a time till the problem is solved.
    This problem didn`t materialise overnight, it progressively got worse. Any help on this matter will greatly appreciated.
    wirral
    42 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Could be a number of things.
    but I'd be guessing its a communication issue.
    i don't really think its really something that can be said over the net with out testing.
    ideally take it too a place that carries out real diagnostics. Not just a code read
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Have you a spare key? Sounds like an immobiliser issue.
    Regular Member simon7257's Avatar
    reading
    If the car and spanner light flashes when you turn the ignition on its usually an immobiliser problem but could be a power issue to the ecu
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 132000
    P0170 code is maf
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by vectra ste View Post
    P0170 code is maf
    A faulty MAF won't stop the car engine from starting though
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 132000
    have you got a spare key ?
    Regular Member azacbr6's Avatar
    Dec 2010
    chesterfield
    Do the simple things first, check battery connectors, Take them off the battery and clean them with a wire brush as well as the battery terminals, I think you have a connection problem, failing that it's the starter solenoid or the starter itself?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 132000
    whats the cars mileage on ?
  1. Vectra not starting
    By hamish123 in forum Vectra C / Signum Car Chat
    Last Post: 14th June 2011, 21:36
  2. Starting to like my vectra now !!!
    By renton608 in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2011, 01:07
  3. Vectra 3.2 GSI not starting
    By RoddyKFC in forum Engine & Drivetrain
    Last Post: 24th February 2008, 10:06
  4. vectra not starting
    By carl in forum Engine & Drivetrain
    Last Post: 28th December 2007, 03:10
