Results 1 to 3 of 3
Thread: Bonnet not releasing,why?
    Regular Member pogo's Avatar
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Engine : 2.0 turbo petrol
    Default Bonnet not releasing,why?
    As above I was out farting about with the car earlier and I struggled to open the bonnet,it's like when you pull the bonnet release nothing happens,i did get it open so I'm thinking the cable hasn't snapped,maybe come loose? Anyone had this prob and how do I sort it thanks
    Dec 2011
    Seaham
    It is possible that it is sticking and needs adjustment. Pull the lever and get someone else to life the bonnet, hopefully it will pop open. Then you should adjust the cable, there is a How 2 on how to do it.
    Basically there is a torq bolt that holds the cable in place on the right hand side of the front panel. Losen the pinch bolt and pull the outer cable to the right, re-tighten the pinch bolt.
    Now pop a good blob of grease ontop the release mechanism, and get sameone to work the release so you can make sure it opens fully and closes fully to lock the bonnet down.
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Ah cheers matey ill have a shifty at it when it's daylight and not raining lol
  1. Releasing hand brake self adjust mech
    By hagga in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2012, 13:00
  2. Releasing handbrake self-adjusting mechanism
    By dnywra in forum Suspension, Wheels & Brakes
    Last Post: 27th February 2011, 11:53
  3. Chugging when releasing the accelerator?
    By guskent99 in forum Engine & Drivetrain
    Last Post: 28th March 2010, 20:22
  4. Siggy Passenger Side Rear door Pin not releasing
    By dennis_signum in forum Bodywork & Interior
    Last Post: 30th September 2008, 18:53
  5. bonnet
    By rich32 in forum Bodywork & Interior
    Last Post: 4th March 2007, 21:31
