Results 1 to 10 of 21
Thread: Passenger Door Locked Wont Open!
    Regular Member Street Hawk's Avatar
    Stockton
    Angry Passenger Door Locked Wont Open!
    Hi All,
    Im gonna need some help with this one.. so as much advice in very simple terms would be great
    two weeks ago now, i came off the road after hitting black ice. done some damage to the car, front passenger door and wing, raditator,& bumper took the impact.
    Picked up another Front passenger door from a Salvage yard same colour but from a Sxi model and mine is a 2.0 Dti LS. anyhow ive fitted the door, the electrics work.. (Window, Mirror, Internal door panel buttons - lock-boot release). But.............
    here's the problem. the central locking on my key fob does all the doors except for this one. The door is closed, and totally locked PERIOD! i can't open it from the inside or outside its pretty much dead locked. I cant open the door to check the pins or even take the panel off. ive pulled the Pin up and pushed it back down again...and....Nothing!
    Is there a way to get the door open another way? some sort of secret release or something from inside? what can i do?
    i cant take the panel off as i think the screws are at the bottom of the door trim (the door is closed so cant get to it), cant open it from the outside. anyone have any idea's at all?
    i really need to get this thing open its driving me nuts! would the wiring be completley different on the Sxi Door (which looks identical and from the same model year) to the DTi?
    I need suggestions or a fix to first be able to get into the door to open it.
    then i need a fix so it doesnt happen again?
    Thanks in advance..
    Street
    Regular Member mrk's Avatar
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    did you swap the door control modules over?i dont know much about this stuff but i gather the modules are coded to the car so you ecu wont rekognise the new one hth
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Correct if you didnt swap doormodule, then you have to get doorcard off
    Trim : improving
    Year : 06
    yippee i got it right,i really know nothing about electrics,just what i read on here.lol
    Stockton
    Hi guys thanks for the reply.. so the door module needs to be replaced, how do i get the door card off when its closed and locked shut? isnt the screws for the door card underneath the door panel? (which i cant get to with the door being closed).
    anyone have a guide or distruction manual?
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    I would start by taking the passenger seat out , at least then you can get at the panel to get it off .
    Full Member Woody's Avatar
    May 2012
    North West (Warrington)
    168 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto (Zavoli LPG with Flashlube)
    Trim : Gsi with loads of "Extras"
    Engine : 3.2 Z32SE (LPG)
    Mileage : 131,000
    Passenger seat is only 3 bolts (including the seatbelt) both at the back end in the rear seat area. Really tight fitting bolts though because they use loctite or something like that on them, so use a long breaker bar and a quality T45 torx (from memory) - you don't want to add to your problems by ruining the head on the Torx bolts.
    Regular Member bigbnlr's Avatar
    Belfast
    I know this is an old thread but did this get resolved, i have the same problem swapped do with identical car everything work but door wont unlock (i didn't change door module)
    May 2012
    168 Post(s)
    Mileage : 131,000
    You need to program the door module fella (tech2) (unless you are using your old module), they are coded to the car and you will need the original security code from the donor car to gain access to it.
    Woody's Vx Ice Addons UK/Eire Distributor of the Comfort Unit and Video Accessories from www.PepaS.cz Designed to enhance your Headunit & Display these add in Additional Data and Reversing Camera & Media. NOW INCLUDES FULL Vxr/OPC NEEDLE SWEEP & LIGHTS Also CD70 Aux In & 3 Line Display Updates.
    Belfast
    Brilliant you're a star buddy, maybe able to get the old one as i swapped the door with a car that's being crushed tomorrow. So just swap the old module in as job done? take i will have to butcher the door card
  1. Passenger door wont open
    By peelmeister in forum Vectra C / Signum Troubleshooting
    Last Post: 28th February 2013, 12:32
  2. door wont open
    Last Post: 10th March 2010, 20:31
  3. Passenger door wont open from outside
    By Vizzeh in forum Bodywork & Interior
    Last Post: 29th January 2010, 02:45
  4. door wont open
    By neverlandandy in forum Bodywork & Interior
    Last Post: 25th January 2009, 13:29
  5. Door locked OPEN! HELP! - Urgent
    By Netstar in forum Bodywork & Interior
    Last Post: 7th April 2008, 13:38
