Thread: wheel shake
    Regular Member franko's Avatar
    Aug 2012
    goole
    Unhappy wheel shake
    hi can anyone help me out i recently bought some 18" alloys from ebay they are original vauxhall wheels the problem im having is that ive got vibration through the steering wheel ive had them balenced on friday but there still the same. they seem to be fine until you get to about 70 to 80 mph and then you get the vibration. does anyone think spigit rings need to be fitted as the standerd ones were 17" can any body help me as i would be gutted if ive been ripped off payed 400 quid for them.
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    If they're originally from a vauxhall then i'd be tempted to say that you don't need spigot rings. I've had this problem before. I had the wheels balanced at one place and had vibrations on the motorway then took them somewhere else for balancing and they were fine. I also like to watch them on the balancing machine to see if they run true as they do seem to be able to 'trick' the machine into thinking a buckled wheel is balanced out.
    Aug 2012
    goole
    cheers for the reply big wilko i stood and watched them balence them one of them is buckled but we put this on the rear would it make a diffrence if these wheels had come off a 3.0 v6 as the huds mybe bigger as my siggys only a 1.9 cdti 120
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    I was told that vibration in the car is a prob with the rear wheels but wobbly steering will be the front wheels. I think all the hubs for the vecs/ siggys are the same dimensions so they shouldnt need any adjustment rings. I'd take them back and get them put on the balancer!
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 137000
    I had vibrations on the motorway i got them balanced and they were fine.
  1. help help? steering shake/wobble
    By dazy75 in forum Suspension, Wheels & Brakes
    Last Post: 28th July 2011, 00:46
  2. shake and management light
    By khile in forum Vectra C / Signum Troubleshooting
    Last Post: 24th January 2010, 18:43
  3. 2.2 DTI engine shake on switch off.....
    By s0501291 in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2009, 11:12
  4. bonnet shake at speed
    By effone in forum Bodywork & Interior
    Last Post: 11th August 2008, 20:34
  5. shake that A##
    By murf2484 in forum Comedy & Humour
    Last Post: 20th May 2006, 12:57
signum shake wheel
