Thread: facelift vec, yellow steering wheel light with exclamation mark on startup
    newport
    Default facelift vec, yellow steering wheel light with exclamation mark on startup
    father in law has a 2008 1.8 sri, not had it long, but just noticed with the ignition lights a yellow light of a steering wheel with exclamation mark, this then goes of with the rest of the ignition lights when started. it hasnt come on when driving yet, is this normal, or pointing towards an early fault?
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Either the Alternator on its way out or the ABS plug under the bonnet needs pulled out and given a clean. Get a multimeter over the battery to check the voltage.
    East Ayrshire
    Trim : SRI XP1
    It's normal as long as it goes off once the engine is started. It's something to do with the electronic power steering
    Regular Member Exclusive BV's Avatar
    West Midlands
    yep it's normal as long as it goes away when the motor is started
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Is this a facelift thing as it doesnt come on on my preface.
    Regular Member Keif's Avatar
    In the Garage
    It's not normal on the pre-facelift.
    I had this on my pre-facelift. The power steering fluid level was low. Topped it up and all was fine.
    West Midlands
    it might be just relative to facelifts then, both mine and the op are 06 onwards
    i even went outside to make sure
    East Ayrshire
    Trim : SRI XP1
    Am I not right in saying that its only facelift that have the electronic power steering?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    No all Vecs and signums (except the 2.8 v6) have ehps. The facelifts show the warning on startup as it has separate lights for all of the systems where as the preface has a window in the rev counter that shows different faults
  1. steeringwheel with exclamation mark
    By nadeem69 in forum Electrical & ICE (including SatNav)
    Last Post: 9th October 2012, 21:00
  2. Steering warning light with exclamation mark
    By bhod73 in forum Vectra C / Signum Car Chat
    Last Post: 10th August 2012, 10:23
  3. Steering Wheel with Exclamation Mark and more....... PLEASE HELP
    By Chris R in forum Suspension, Wheels & Brakes
    Last Post: 10th July 2012, 11:06
  4. Steering Wheel/Exclamation Mark
    By Tam80 in forum Suspension, Wheels & Brakes
    Last Post: 1st May 2011, 21:36
  5. Replies: 7
    Last Post: 22nd December 2006, 23:23
vauxhall vectra steering wheel with exclamation mark
vauxhall corsa yellow ligjt looks like steering wheel with exclamation mark
vauxhall vectra power steering warning light
vectra c yellow steering wheel
vectra c power steering warning light non start
steering wheel with exclamation mark corsa
steering wheel exclamation mark vauxhall vectra
exclamation mark on vectra
https:www.vectra-c.comforumshowthread.php180240-facelift-vec-yellow-steering-wheel-light-with-exclamation-mark-on-startup
steering icon warning light on vectra c
yellow steering wheel light vauxhall
vauxhall vectra c steering yellow light ignition
vectra c steering wheel with exclamation mark
vectra steering light
vectra c steeringwheel exclamationmark
