Thread: Vectra C 2.0 Dti Starting Problem.
    Jul 2012
    Devon
    Question Vectra C 2.0 Dti Starting Problem.
    I have a starting problem with my vectra c 2003 2.0dti. It will start when facing downhill everytime but won't start sometimes when facing uphill. It has only just started doing this. I took it to the garage and they checked all the fuel pipes for leaks and replaced one piece of pipe. I took it home and left it overnight facing uphill and it started fine the next day. But then left it another 6 hours and it started then stalled immediately and wouldn't start again. I rolled it down to the flat left it an hour and after turning over the engine for 20 seconds it started.
    From what I read people say change the leak off pipes but vauxhall want £24 for the pipe and £15 for connectors is this worth doing? . Also my garage said try changing the fuel cap as it may not be sealing, could this be the cause?
    Thanks in advance for any advice.
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    nothing to do with the fuel cap , will either be leak off pipes ( yes they are a bit pricey ) or the injector seals .
    change the leak off pipe & see what happens , if no joy then its injector seals .
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    buy a 1.5mt lenght of spill pipe hose from your local motorist shop and cut them to fit,don't forget to fit a new piece to the fuel pump ( I know it's fiddley )hose is about £5 to £6.
    Jul 2009
    Engine : 20 Dti
  1. Vectra 1.9 16v starting problem
    By z19dt in forum Engine & Drivetrain
    Last Post: 30th December 2012, 17:33
  2. Vectra C 2005 CDTi 1.9 8v - Starting Problem
    By aaronfenwick in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2012, 12:44
  3. 2006 vectra 1.9cdti starting problem and i=oil leak on start up
    By tomstubbings in forum Engine & Drivetrain
    Last Post: 24th September 2011, 10:01
  4. vectra 04 cdti 120 starting problem
    By andyman201 in forum Engine & Drivetrain
    Last Post: 24th December 2009, 20:15
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
vectra c 2.0 dti starting problems
vauxhall vectra c 2.0 dti starting problems
vauxhall vectra c 2.0dti starting problems
vauxhall vectra c 2.0 dti immobiliser problems
vauxhall vectra 2.0 dti starting problems
vectra wont start when facing downhill
