Thread: Water in boot - not aerial???????
    liverpool
    Default Water in boot - not aerial???????
    Fitted new aerial base due to water in boot. It did look bit perished but roof lining did appear dry and no stains. This was confirmed when today the pond was back following big thaw. The aerial is fitted tight and sealed so confident not problem. Water seems to be leaking in passenger side by fuses. But closer to backseat than rear light looking were water collecting. Believe can leak in in tracks for roof rack? If so what should I be looking at and what's fix? Help appreciated as not had spare wheel/boot mat in place since bought car and frustrating now.
    Hanging Heaton / Batley
    14 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Not sure on the rails but i think people have also has issues with the seals on the rear lights?!?!...
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    Mine was a crack in the bodywork by the left hinge, when the boot was open it was visible just were the roof joins the resease for the boot lid.
    Regular Member azacbr6's Avatar
    Dec 2010
    chesterfield
    Have a look at this post, lots of people here had the same problem.
    http://www.vectra-c.com/forum/showthread.php?153087-water-in-boot&highlight=aerial
    liverpool
    Leak appears to be more towards back seats rather than rear lights, but will remove clean and tighten to check. Will look at hinges etc. Have checked rubber is all ok. looked at the thread so will now see if I can work out how to get access to that rivet. Help appreciated.
    scotland
    mine is the same , only way I can think of narrowing it down is using some food colouring at either of the rivets first then roof bar anchors , different colours for different places though .
    liverpool
    My plan after another overall recheck and looked at rivet in roof rail, is to tape up each possibility 1at a time with really strong industrial tape which I know won't leak any water thru. My only concern is it damaging paint work/lacquer when removing it, but bit stumped what else can do.
    wirral
    26 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Check all sealer joints etc done a corsa c that was leaking through factory sealer on the back panel
    Regular Member shinyb1's Avatar
    Jul 2011
    wigan
    mine was leaking from the rear light , the seal was not fitted correctly. it was filling my spare wheel well up and also running down behind the trim towards the rear seats.
    liverpool
    Quote Originally Posted by shinyb1 View Post
    Thanks. Am off back end of the week and will be checking lights, roof rail, etc
  1. Water in spare wheel well after aerial repair
    By coooky in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2013, 21:54
  2. water in boot
    By keggy77 in forum Bodywork & Interior
    Last Post: 15th May 2012, 13:03
  3. water in the boot
    By billyyoung in forum Bodywork & Interior
    Last Post: 9th January 2008, 18:58
  4. Water in the BOOT!!
    By Silver V in forum Vectra C / Signum Car Chat
    Last Post: 30th May 2007, 09:06
  5. Water in boot - Please help
    By sanasana in forum Bodywork & Interior
    Last Post: 2nd April 2006, 10:27
