Results 1 to 10 of 11
Thread: cdc40 opera - aux out ??
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    Default cdc40 opera - aux out ??
    i have read / heard of fitting an aux out on the cdc40 opera, something about using the DAB output irrc but cant find any info on it, does any one have any idea how it is done please ???
    fancy adding it to mine so the missus doesnt touch my cd's in the deck, last thing i need is pink n stuff in there when i am driving !!!!
    any help appreciated
    cheer's in advance
    Midlands Mod Shop - NFFC.
    Regular Member sweepcat9's Avatar
    Sep 2012
    West Yorkshire
    A Polish forum suggests using the DAB inputs (+,-,GND) on the head unit and getting the CDC40 Tech2'd to say it has a DAB installed. The screen will read "DAB error" but supposedly still plays the audio from the cable.
    I've not done it so I cannot confirm if it works or not...
    Trim : Get a
    thanks for that, will have a look into it...
    Regular Member stephen_brady's Avatar
    Jan 2012
    N.Ireland
    There's a thread on here somewhere about it, I came across it when I was looking at aux in possibilities. A guy claimed he'd done it but never really came back to confirm. Robsey suggested a wiring diagram based on what they guy said, but I can't recall if anyone followed it through.
    Sep 2012
    West Yorkshire
    Just seen this on Ebay Germany...
    German Ebay Link
    Use google translate comes up with this:-
    This AUX cable allows you to connect external MP3 players, portable CD player iPhone, iPod or laptop to the standard Opel audio systems from about 2004 up to the must / Quadlock plug. The adapter connects to the CD changer port of the device. (Only for units with CD changer port) The integral CD changer function is preserved.
    Compatible with the following radios Opel:
    CD30 MP3 with AUX preparation
    CDC40 OPERA with AUX preparation
    CD70 NAVI with AUX preparation
    DVD 90NAVI with AUX preparation
    Year in year 2004-2009 models Opel Astra, Opel Zafira Year 2005-2011, 2004-2009 Opel Tigra
    Specifications:
    Most connector 1 x (12-pin)
    1 x gold-plated 3.5 mm stereo jack
    Cable length 70cm
    Important: adapter is only compatible with selected car radio with AUX input enabled. To activate when audio input is not active, it is required by the authorized Service Opel TECH2 (software version no older than 10.10.2007)
    Trim : Get a
    Quote Originally Posted by sweepcat9 View Post
    German Ebay Link
    nice find that, will have a ask of a certain man i know if it will do the trick....
    Regular Member Gubmint Agent's Avatar
    Feb 2011
    Feels a lot like Kathmandu.
    Trim : Sri
    Engine : 2.2 Direct
    Having just connected a suitable 3-wire cable in this manner, I can confirm that it doesn't work. No sound, nada, zilch. Just shows 'DAB box error' on the display still.
    Trim : Get a
    i am going to be speaking to a man who should be able to point me in the right direction very soon about this aux in the DAB bit, i will update when i can
    Regular Member Robsey's Avatar
    North East Cheshire
    6 Post(s)
    Trim : Energy
    Mileage : 101,000
    I have recently noted that CDC40's upto early 2007 will have three pins labelled DAB L, DAB R and DAB -.
    CDC40's from mid-2007 onward will label the same pins with Aux L, Aux R and Aux -.
    Sounds like a firmware and componentry upgrade may do the trick for head-units with the pins labelled DAB etc,
    Similar to how it does on the CD70.
    Dec 2011
    Essex
    Engine : CDTi 1.9 150
    Year : 07
    Mileage : 61000
    Think the thread title is meant to be aux in not out
    I have this weekend done this mod using the the DAB +R, DAB +L, and DAB GND cables.
    It works great and i am very happy with it.
    I used a 4 pole relay to switch between the aux and DAB unit and it works a treat.
    I got the aux plugged into my bluetooth unit and now i can stream music wirelessly
    I put a push button switch on my dash to switch the relay.
    All the info for this i got from this thread, it was very usfull so thanks for the info.
    http://www.vectra-c.com/forum/showthread.php?107617
  1. CDC40 Opera on the way
    By Teapot in forum Electrical & ICE (including SatNav)
    Last Post: 16th February 2013, 12:30
  2. Cdc40 opera
    By paulcdti150 in forum Electrical & ICE (including SatNav)
    Last Post: 26th February 2011, 16:26
  3. CDC40 Opera
    By LeeU in forum Electrical & ICE (including SatNav)
    Last Post: 28th December 2010, 12:43
  4. CDC40 opera
    By DaveD in forum Vectra C / Signum Car Chat
    Last Post: 12th July 2008, 17:52
  5. CDC40 Opera and MP3
    By greeningr in forum Electrical & ICE (including SatNav)
    Last Post: 12th February 2007, 13:07
cdc40 opera external in
cdc40 tech2
cdc 40 opera aux input
cdc40 opera aux jack
cdc40 opera extern in
