Thread: Signum Number Plate Light
    Regular Member R13hard's Avatar
    Devon
    Engine : 2.0 Turbo
    Default Signum Number Plate Light
    Is it possible to swap the number plate lights from a Signum for the number plate lights off a Vec-c?
    My Signum ones screw in and the Vectra C ones seem to clip in.
    Are they the same size and shape to fit?
    The screws on my are ruined and I am looking at just replacing with the clip in type
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    I'll measure the square hole on mine so you can compare if want?
    Devon
    Engine : 2.0 Turbo
    if it's no bother, that would be great thanks
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    No worries...
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    Right... The hole itself is about 105mm by 34mm but has small I'd shaped recess to sit on a tad shallower...
    The unit itself is smaller where it would need to clip, 85mm by 28mm hole, that's what I'd trim to if fitting
    You'll Prob have to do some modding to fit however or I think vauxhall would have just used the Vec units to keep costs down...
    Devon
    Engine : 2.0 Turbo
    Thanks for doing that!! - It looks like its a very similar size but as you say some modding required.
    I've drilled out the old screws and i think that if I cut away some of the existing trim then it should leave enough space for the clip in light on one side and a reverse camera on the other.
    it's dremmel time......
    Mar 2012
    Cardiff
    Trim : Elegance
    Engine : 2.2 Petrol
    Hi,
    I have the same problem on my Signum (screws rusted to falling apart).
    How did you get on?
    S
    Regular Member d_ghedia's Avatar
    Oct 2007
    Berkshire
    Vehicle : Vauxhall Signum
    Engine : 1.9 CDTI 150. Manual
    I don't think they are the same size. Signum number plate lights are the same as those on a vec b.
    Regular Member roverjay's Avatar
    Feb 2012
    Skelmersdale
    Vehicle : Vecta
    Trim : sri
    Engine : 1.8
    Mileage : 39000
    had same problem on my siggy with rusty screws iirc the stealers were around the £5 mark or as d_ghedia says go to a breakers and get a pair or Vectra b ones
    VIP-Member
    Dec 2010
    Glasgow
    Vehicle : 1.9 Cdti Signum
    Engine : z19 DTH
    Mileage : 160000
    im sure the zafira ones work well too
    http://www.ebay.co.uk/itm/2705609508...800%26_rdc%3D1
    this is the ones i got last year
    Had to destroy the ones that were in as the screws were gubbed - comes with screws btw (not bulbs)
  1. Number plate light
    By ronaldodg9 in forum Vectra C / Signum Car Chat
    Last Post: 6th September 2012, 05:18
  2. Exploded diagram of Signum number plate light holder?
    Last Post: 2nd July 2011, 17:58
  3. Tail light/number plate light wiring...
    By kyuudousha in forum Electrical & ICE (including SatNav)
    Last Post: 26th December 2010, 12:34
  4. Signum number plate light
    Last Post: 3rd November 2010, 22:32
  5. Number Plate Light
    By kiwigolfer in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2009, 23:10
