Results 1 to 10 of 29
Thread: Vectra 1.9cdti 150bhp 0ver Fuelling.
    Aug 2011
    Dudley
    Default Vectra 1.9cdti 150bhp 0ver Fuelling.
    Hi Guys,
    I have an intermittent problem with what I believe to be over fuelling. Please correct me if I am wrong.
    The car starts and idles fine but after a few minutes of idling it goes lumpy and starts chugging, also the instant fuel consumption goes from 0.1g/h to 0.3g/h. All the injector timings start to rise and fall as well.
    There are no error codes, spanner light or eml on. There is a small amount of whitey blue smoke from the exhaust when the problem starts.
    It's had new inlet manifold, egr, boost sensor cleaned.
    Any idea's? Dont want to end up wrecking the engine.
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    does it do it from cold? or only when warmed up?
    Aug 2011
    Dudley
    It does it after a few minutes from cold and when it's warm. It will also do it when you pull up at traffic lights etc.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Do you have a DPF? Could be doing a regen but not getting a chance to fully complete.
    Aug 2011
    Dudley
    Yes it has a DPF but shows 0% regen when it does play up. Also when it starts to regen I get 0.8g/h to 0.9g/h on the instant consumption. I'm sure as well that it would not start to regen when the engines cold.
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Check CTS
    Aug 2011
    Dudley
    CTS ? and where is it located.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Coolant Temp Sensor. On the thermostat - has a connector attached to it
    Aug 2011
    Dudley
    According to my snapshot of data done this afternoon it reads 79 degrees.
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    96 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    that sounds about right. I assume when the engine is cold it shows the correct temperature then too?
  1. 1.9cdti 150bhp 55 plate vectra idle speed problem
    By Whiteknight841 in forum Engine & Drivetrain
    Last Post: 21st January 2015, 07:55
  2. Loss of power issue (1.9CDTi SRi 150BHP, Vectra C)
    By Big Sie in forum Engine & Drivetrain
    Last Post: 20th April 2010, 17:46
  3. Help Please. Vectra 1.9cdti 150bhp
    By collieq in forum Engine & Drivetrain
    Last Post: 1st January 2010, 13:05
saab 93 1.9 tid overfueling loss of power.
does a ecu learning driving style vectra cdti
