Thread: Anti-Roll Bar Bushes
    Apr 2012
    Wexford
    Trim : SRI
    Engine : 1.9 150
    Mileage : 146,000
    Default Anti-Roll Bar Bushes
    Well lads, went to change the bushes today, i measured the bar, it was 24 mm the same as the womans vectra when i did them on that few months ago, so i ordered the same bushes. I notices there was somthing up when i had the bolts out the metal bracket holding in the bush would not simply pop off, i had to prise it and beat it with a chisel and hammer and eventually got it off to find the bush is completely different, its like hard plastic with just rubber in the middle and it split in 2 halves, theres also 2 little lugs on the bush that clip into 2 holes in the bracket... ive never seen bushes like this before and the auto factors hasnt got them listed either. Will i just have to go to main dealers or does anyone know why these are different to the normal types?
    VIP-Member MCD's Avatar
    NE Manchester
    32 Post(s)
    Vehicle : 2007 Vectra
    Trim : SRi XP T Saphirre Black
    Engine : z20net
    Mileage : 80k
    That sounds like VXR bushes to me? Have you got uprated running gear such as IDS shocks and sport? My cdti has, and as such comes with VXR anti roll bars. What you write above sounds identical? if you don't want VX two piece bushes, powerflex do them for about £40. Have a look on eBay under powerflex two piece arb bushes.
    Apr 2012
    Wexford
    Trim : SRI
    Engine : 1.9 150
    Mileage : 146,000
    Im not sure if the shocks or that have been uprated to be honest as i only bought the car 2 weeks ago, how would i know if they have? Is there any markings on them that could tell me? And ill have a look on ebay now thanks
    East Ayrshire
    Trim : SRI XP1
    They tend to be fitted to the facelift ones. 2 piece bushes are quite common on them. I changed mine for powerflex ones a couple months back, but you can get the genuine ones from VX for just a few pound
    Apr 2012
    Wexford
    Trim : SRI
    Engine : 1.9 150
    Mileage : 146,000
    Just rang the main dealer, they said they havnt got them in stock but will order them in, €6+vat each so not too bad
    Apr 2012
    Wexford
    Trim : SRI
    Engine : 1.9 150
    Mileage : 146,000
    ****in cu*ts in main stealer, ended up being €37 as the bushes came in 4 pieces and was counted as 4 parts not 2
    if i had to know that i would of got powerflex ones, they were only €43!
    East Ayrshire
    Trim : SRI XP1
    I think i'd have told them to stuff them and just walked out
    Apr 2012
    Wexford
    Trim : SRI
    Engine : 1.9 150
    Mileage : 146,000
    Thats what i should of done!! There some pain to do compared to normal bushes
    And now that i have done them it still hasnt cured the problem i checked everything in the front and all was gone is a wishbone and droplink but after doing them i could still hear a little rattle when on rough ground or going up on a speed ramp and can feel it through the steering wheel, so the only thing i thought it might be was the bushes, but there changed now and its still there!!
  1. Anti roll bar bushes
    By Mark-R in forum Handling & Braking
    Last Post: 27th April 2012, 14:13
  2. Anti Roll Bushes...Which ones?
    By n_hudson in forum Suspension, Wheels & Brakes
    Last Post: 21st February 2009, 12:17
  3. anti roll bar bushes
    By mhvcbv in forum Suspension, Wheels & Brakes
    Last Post: 8th July 2008, 17:53
  4. Anti-Roll Bar Bushes-How??
    By Vaux-Man-G in forum Suspension, Wheels & Brakes
    Last Post: 29th June 2008, 20:09
  5. i think i need anti roll bar bushes but!!
    By EURO G in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2008, 13:30
does vauxhall vectra 08 ids on anti roll bar
