Results 1 to 3 of 3
Thread: Towbar wiring?
    Jul 2010
    Londonderry Northern Ireland
    Default Towbar wiring?
    Borrowed another vectra tonight to tow my car transporter when i plug in my lighting board i am only getting 2 volts to the tailight bulbs and only 2 volts at the plug on the car. any ideas?
    Dec 2011
    Seaham
    CHeck the rear fuses in the boot, that is where the towbar wiring plugs into. Also make sure there is a good earth as you will find all lights will light up but dimly.
    Regular Member benamir's Avatar
    Oct 2010
    Swadlincote
    Hi Ryan, You need to check the lighting board is ok first ,try it on another car with towbar , Also testing towbar o/put reqs you to know the individual connections with respect to it's earth pin If the socket on the car is wired up using the GM cable then are the brass connections all clean & socket in good condition ? I presume you are using a black 7 pin connector ?
  1. Towbar wiring need some help please
    By jel0611 in forum Electrical & ICE (including SatNav)
    Last Post: 4th April 2012, 11:37
  2. Towbar wiring
    By Andyc6845 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd May 2011, 17:59
  3. Towbar wiring car has pdc
    By waltz in forum Electrical & ICE (including SatNav)
    Last Post: 19th June 2010, 20:11
  4. towbar wiring!!
    By kojak01 in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2009, 16:07
  5. towbar wiring
    By dave t in forum Electrical & ICE (including SatNav)
    Last Post: 31st July 2007, 12:09
