Has anyone had to replace a wiper linkage? I have an 05 CDTI & it won't stay on!
Can anyone tell me if it's the ball or socket & if it's an easy fix?
Thanks in advance!
Thanks in advance!
What do you mean wont stay on .
I had the same problem not so long ago mate. It's a splined fitment then screw on to hold it in place. The splines have probably had it. I went and got it welded together However, while this works a treat and it will never come apart again, when the linkage or the motor breaks you will have to replace both
HTH's mate
£70 dealer part mate. You can fold a plastic bag over the ball and pop the socket back on, its worked on mine for over 6 months.
I did a fix on this to a mates car at work. The joint that was coming apart was the one at the drivers side of the car.(bottom right corner of the windsceen) I was able to get into and wash out the socket with some solvent to remove all the dirt and remnants of grease and then half fill the socket with araldite put a thin layer of grease on the ball and popped it all back together, the grease stopped the araldite sticking to the ball and the araldite took up all the wear and tear in the socket. When the glue was set we switched on the wipers and all worked perfectly plus the joint could not be pulled apart. I dont know how long this fix would last but when he sold the car two months later the wipers were still working perfectly well
