Results 1 to 10 of 13
Thread: Frost Inside Car but NOT Outside .
    Regular Member HITFACTORY1403's Avatar
    Mar 2011
    NEWCASTLE UPON TYNE ( Shiremoor )
    Default Frost Inside Car but NOT Outside .
    It's been snowy in the North East like a lot of the rest of the U.K.
    So it's cold ....... L.O.L.
    But this morning the out side of the car was frost FREE .
    But the INSIDE windows were covered in frost and i had to scrape the windows inside ......... L.O.L.
    It's not like the car has been standing for days , i last used it at 6 P.M. last night and had the hot heaters on and then used it at 9 A.M. today .
    See Pictures . ( that frost is from scraping the windows )
    West
    You have probably got damp carpets due to all the snow thawing off your feet... run the aircon with the heater turned to warm, it should help dry the inside of the car out.
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    It's a renault, even in the cold it surrenders lol
    Mar 2011
    So does that mean the inside is colder than the outside after the car cools down ?
    Or maybe the early morning rise of temperature thaws the outside leaving the inside unthawed ?
    West
    No... but if theres no damp in the outside air due to the cold then theres no frost on the outside of the screen, the condensation on the inside has simply frozen through the night.
    I had no frost on my windscreen & it was -6 when i started my car this morning
    Regular Member mrk's Avatar
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    maybe yo've had the heater on recirculate as that would do it
    Regular Member dave1419's Avatar
    Jun 2012
    newcastle upon tyne
    9 Post(s)
    Vehicle : 1.8vvt
    Engine : 1.8xer
    Mileage : 20,000
    Will be the condensation off people's breath--and as you know that where we live its always colder than everywhere else in the uk lol Got in car this morning and its garaged and it showed -4 on the outside temp---- --Dave
    Mar 2011
    So if i have this correct ......
    Eventually the car inside will be as cold as outside
    and if the water / snow isn't on the outside , there's nowt to freeze ,
    then the internal rising condensation from snow / rain on feet or breath will freeze inside .
    Dec 2011
    Seaham
    I would get some Head and Shoulders, that looks like a bad case of dandruff......
    Regular Member ph67's Avatar
    Northamptonshire
    Basically there was more moisture in the air in your car when it froze up that in the air outside you car.
    Warm air holds much more moisture than cold air, if you had the heater on last night and there was dampness in the car that the warm air had picked up (or dried out) then the moisture will still be in the circulating air in the car giving you a high realtive humidity - that will explain the moisture inside the car.
    It was -2c last night around my way but there was no ice on the outside of the car because there was low relative humidity outside meaning there wasn't enough moisture in the air outside to freeze on the car.
    The moisture in the air in your car would have slowly condensed on the glass as the temperature lowered (as cold air cannot hold as much moisture as warm air) and then it woul have frozen.
  1. Jack frost has attacted
    Last Post: 10th October 2012, 07:10
  2. Auto lights/wipers and 'frost'
    Last Post: 20th January 2012, 11:55
  3. First Frost
    By silverhairedracer in forum General Chat
    Last Post: 19th October 2007, 02:28
  4. New look inside
    By nutron in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2006, 18:41
vectra 2007 condensation inside car
