Thread: External temperature Gauge
    Regular Member keith1983's Avatar
    Sheffield / Spalding
    Vehicle : Vectra 1.8 SRi
    Engine : Z18XE
    Default External temperature Gauge
    Well my external temperature gauge has lost the plot, It hasn't dropped below about 11 degrees for some time now regardless of the weather. Are there any common faults with these or easy and cheap buits its worth getting and swappuing over to see if it sorts it? I know it's not exactly massively important but it would be nice to have it working correctly.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    You can check the resistance to see if its faulty, but they aren't expensive to replace.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    It's also a good move to check for corrosion in the multiplug too on the passenger side, roughly same height as the temp sensor and almost in line with the inner edge of the headlamp. When mine went silly last year that's where the true fault lay... pig to get apart initially, but once you do, wire brush, wd40, clean the contacts and all was well.
    Have a read of this : http://www.vectra-c.com/forum/showth...76#post1690176
    Engine : Z18XE
    I'll have a look into that chaps, thanks for the ideas!
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 141000
    id go with john on this one cheap fix
    http://www.ebay.co.uk/itm/Vauxhall-O...item4d08e3d532
    The temprature sensor is located in the grill at the front in the middle at the bottom ( when viewed from above, with the bonnet open).
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 141000
  1. temperature gauge
    By rfc52 in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2012, 15:20
  2. Temperature gauge
    By ziggy1 in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd November 2012, 02:35
  3. External Temperature Sensor Location
    By ijk571 in forum Electrical & ICE (including SatNav)
    Last Post: 21st June 2012, 21:02
  4. External Temperatuee Gauge
    By Vectra_Wilky in forum Electrical & ICE (including SatNav)
    Last Post: 22nd March 2010, 23:29
  5. Corsa C External temperature sensor
    By LJ sxi-nav in forum General Chat
    Last Post: 2nd March 2009, 08:36
