Results 1 to 10 of 13
Thread: Problem with 1.8 VVT and jerky pulling away
    Jan 2013
    Birmingham
    Default Problem with 1.8 VVT and jerky pulling away
    Hey there,
    I'm new to this forum, hi to everyone
    2 weeks ago I purchased my vectra C 06 plate,
    41000 miles on the clock, full service and excellent motor!
    Anyways, after driving it for 2 weeks I have realised that sometimes I get some clutch judder, usually when it's cold and usually until I've used the car for a while.
    i have read up on this and I have seen that apparently vauxhall did know about this problem and have come up with a new clutch and flywheel or something,
    Now I'm a mechanic myself but if I could get this done by vauxhall that would be great but I don't want to get robbed.
    What I wanted to know was is this a recall issue or did they just put a mod out to be done while the vehicles were In warrenty?
    sorry if this has been asked many times,
    Ash
    Regular Member Envy's Avatar
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    I had the same problem and lived with it for quite a while.
    My coilpack then failed. Once i replaced this i noticed that pulling away was a dream and no more judder .
    The coilpack was second hand and cost me 60 quid all in.
    Hope this helps
    Regular Member yessof's Avatar
    Jan 2008
    west yorkshire
    Vx knew about the problem across the 1.8 range. They were replacing the complete clutch assembly as long as the car was still covered by warranty and had less than 18000 on the clock. I tried to get mine changed but the stealers warned me if the fault was "driver error" I would have to pay.
    I had a complete clutch assembly fitted by a reputable garage in Leeds,engine and gearbox mountings checked. Cost £375 and it didn't make a bit of difference. Still got the judder, worse when reversing uphill. Think your going to have to live with it.
    Regular Member jamiedvvt's Avatar
    Sep 2012
    Inverclyde
    Vehicle : Vauxhall Vectra
    Trim : Sri
    Engine : 1.8 vvt
    Mine is the very exact same i posted no to long ago with this problem and as above reversing is the worst
    Jul 2010
    Kent
    I've not had any problems with my 1.8 VVT SRI in the last 2 years, though it's a Dec 2008 with only 14k miles, so as one of the last Veccy's, may have a modified clutch?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 143000
    Quote Originally Posted by yessof View Post
    what he said there are a few threads on here regarding the 1.8 clutch judder
    mine is the same
    here you go
    http://www.vectra-c.com/forum/showth...ight=juddering
    Jan 2008
    west yorkshire
    Seem to remember that VX were supplied with a batch of faulty clutch plates which were fitted to all 1.8's accross the range. Thats why they were replacing them unless they could blame the driver. It wasn't a recall, you just had to try your luck with a stealer. Mine is an 06 plate sri. The judder is more of a niggle than a problem.
    Dec 2011
    Seaham
    Yessof
    But you have had a complete clutch assembly fitted and it is still doing it?? Then it cannot be the alleged faulty part that Vauxhall fitted??
    Barrow In Furness, Cumbria
    Mine is ok. 2008 Vectra 1.8 SRi.
    I test drove a 2006 Vectra Design though and that did it pretty bad.
    Jan 2008
    west yorkshire
    Had the clutch replaced because that seemed to be the cause of the judder. Now whether the flywheel was scoured,I dont know. I didn't have it replaced, possibly this may cause the judder. As I said that was 4 years ago, 30,000 miles later it's just the same,no better,no worse. Some people say in old posts that a replacement cured their problem. No doubt there are lots of people who had the clutch replaced and it's still the same. If you look at old threads you will see that VX admitted that the clutch friction material was faulty,not just on Vectras but accross the entire 1.8 range.
  1. Not Smooth, Jerky, Misses
    By 11mallard in forum Engine & Drivetrain
    Last Post: 24th March 2013, 13:15
  2. Jerky at low revs
    By larrysSRI in forum Engine & Drivetrain
    Last Post: 12th April 2012, 14:25
  3. astra 1.7 jerky
    By pubcarking in forum The 'Off Topic' room
    Last Post: 15th April 2010, 23:00
  4. problem when pulling away at lights etc.
    By chrish in forum Suspension, Wheels & Brakes
    Last Post: 8th May 2007, 14:40
  5. Jerky when queing in 1st & 2nd Gear
    By Palmo in forum Engine & Drivetrain
    Last Post: 1st March 2006, 15:51
vauxhall vectra 1.8 sri problems
vectra c 1.8 juddering
vauxhall 1.8 jerky
vauxhall vectra 1.8 vvt sri problems
vectra 1.8 vvt problems
vectra c 1.8 vvt fix clutch judder
why is my clutch slipping vectra vvt
vectra 1.8 rumble pulling away
vauxhall 1.8 vvt engine problems
vectra 1.8 jerky
vectra c 1.8 jerky
why does my vectra c 1.8 problems
vectra c 1.8 vvt problems
vectra 1.8 vvt jerky
vectra 2007 1.8 from suspension faults
vauxhall vectra 1.8vvt sri 2007 common faults
vauxhall zafira jumpy suspension when pulling away
