Thread: Wing mirror dissasembly?
    Hanging Heaton / Batley
    21 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Default Wing mirror dissasembly?
    Can the arms be removed and the colour coded parts so only the base is left?
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    In a word yes , if you remove the glass you will see 4 tabs at the back of the cover compress these and the cover will pop out .
    For the small section between the mirror body and the door its probably best to remove the whole assembly.
    The mirror body is held by three screws the third is only accesible after the door card is removed .
    and still loving it
    21 Post(s)
    Mileage : 110k
    So once all that's done it should look like someone's ripped it off and there's just the plate there? Good stuff
    newport
    just done it on the father in laws sri, no need to take door card off if you have a torx allen key, we had a black one from the sri we are breaking, so he swapped all the silver bits onto that then i changed the mirror onto the car for him.
    if you pull the little triangle tweeter trim off, that gives you access to the top and bottom torx screw, then the 3rd you pull off a little plastic gromit.
    but my father in law had all the coloured bits swapped over before i even got there, without taking the mirror off the car, so it is do-able
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Quote Originally Posted by taffy bhoy View Post
    My door mirror is loose on the door mount. When I fold the door mirror in there is a lot of play. Is it just a case of what you just said, and remove the tweeter door trim and tighten the torx bolts?
    newport
    yep, three bolts holding the mirror in place, if it was like mine when i got our sri, someone has replaced the mirror at some point, and didnt bother putting the awkward bottom bolt back in
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Thanks taffy, another job soon when the weather warms up.
  1. Wing mirror
    By raddish in forum Vectra C / Signum Car Chat
    Last Post: 11th April 2010, 17:25
  2. Wing Mirror
    By bigbnlr in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 22:35
  3. Wing Mirror
    By edrevell in forum Vectra C / Signum Car Chat
    Last Post: 8th October 2008, 13:56
  4. Wing mirror
    By blom157 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2008, 17:32
  5. Wing Mirror
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 30th November 2007, 23:36
