Thread: Will et45 fit?
    liverpool
    Default Will et45 fit?
    Have the chance of a set of 19" Vxr alloys. Not sure what offset is until view tomorrow. Will et45 fit or is et43 limit? Do intend to eventually lower 45 mm. Thanks for help.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Don't know but The wheels will sit bit too far into the arches. 19" VXR? I didn't think they were ET45. I'd imagine ET45 may scrape the wheel arch lining.
    Regular Member pogo's Avatar
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Engine : 2.0 turbo petrol
    If they are genuine vxr rims mate they will fit no probs,loads of vets on here with 19s and lowered with no probs
    liverpool
    They are ronal diamond cut Vxr alloys off a Astra Vxr. So post 07 ( i believe) which when I have looked at others for sale seem to be et45 but seller thinks et43 but not checked. If et43 will buy them as am pretty sure fit no probs but not sure about et45.
    Hanging Heaton / Batley
    18 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    They will be 43... But if there where 45 its only 2mm, catch inner arch liner on full lock only, but most 19"a do anyway...
    liverpool
    Thanks for help. If no cracks then will be buying.
    Regular Member rockafella8587's Avatar
    Nov 2011
    Akrotiri, Cyprus
    Would 10mm spacers compensate for the offset?
    Regular Member Grimy's Avatar
    ET38 x 8"wide rims on eibachs fit no problem. No rubbidge anywhere, so ET45 will be no problem at all.
    Edit, sorry, I didnt realise you ment the inside of the arch, I.e. the shock absorber side of the rim. I'm not sure how much space there is there?
    Last edited by Grimy; 25th January 2013 at 12:00. Reason: Re read original post properly
    liverpool
    Leemarksmith you were spot on, alloys et43. They were also cracked so the search continues. Thinking maybe go for 18s as roads not great by me and most 2nd hand 19s are either cracked or repaired.
    Jun 2011
    wolverhampton
    I'm looking at a set of et 45 but are 8.5 wide so I'm guessing it's gona rub so no good
  1. ET45 or ET35 for 19" Wheels
    By Brian150 in forum Suspension, Wheels & Brakes
    Last Post: 24th April 2012, 17:42
  2. VXR Alloys - Will offset ET45 fit 314mm Brakes
    By dae36 in forum Suspension, Wheels & Brakes
    Last Post: 3rd March 2010, 14:47
