Thread: No Drive.....
    Regular Member sterie's Avatar
    Nov 2011
    staffs
    Default No Drive.....
    Hi,
    My car is a 2003 Vectra 1.8 SRI
    I was at some traffic lights, at the green light i drove off. The car drove fine, i was driving with a purpose but not thrashing it (normally i drive like a nun and i get 38/40 mpg!!!) because i wanted to get home and have a pee. Changed to second and put my foot down some drive/power then nothing! I coasted to a stop in a lay by.
    I can get all gears, the clutch pedal goes up and down but there seems to be very very little pressure, there wasn't before though ?? (i think??)
    There is no grinding noises and the car will not actually engage a gear, i can put tyhe lever into a gear though
    I have looked at some threads which seem to point to gearbox and diff etc but does anyone have any idea? there was no oil that i could see.
    Please help, i've got to use her car, it's a **** ....major
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Sounds like a gearbox or flywheel failure
    Regular Member Das's Avatar
    Turdsville
    35 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Sounds like clutch failure to me, although the F17 is known to spit its diff from time to time, although if it did this id expect to see box oil on the floor. Either way the box needs to come out me thinks. You could take the bottom plate off the gearbox to check the diff though.
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Was there any warning when it happened? A bang, crunch, or any other noise?
    wirral
    33 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Will it go into gear if turned off?
    Try taking up the drive again
    Regular Member stevoxsi's Avatar
    Sep 2012
    Coleraine, Norn Iron.
    Vehicle : Insignia
    Trim : Sri Vx-line
    Engine : 2.0 Cdti 160
    Year : 2011
    What's the linkage on a vectra? If its cables one of those might have snapped. Happened to me in a master van once.
    Nov 2011
    staffs
    Hi, Thank you for all the replies. It goes into gear fine engine off or running. I did not hear a bang or a crunch my son was with us and he says he heard something, like a thump but we were driving over a very poor road surface (as is usual.....)
    I turned it off and on but it wouldn't drive. I have been back to have a look at it, i hate to leave it in a lay by but....
    Looks like i'm going to have to get a tow to a garage
    Nov 2011
    staffs
    Post
    Hi,
    In the interests of the forum and for future problems other owners might come across etc...... It's the drive shaft!
    The guy at the garage has cleaned the planetary gears up and cleaned the diff out and he is fitting a new drive shaft later, no mention of cost but at this stage i'm pleased it's a GM product and not something Uber expensive or for that matter molto expensive
    Still i hope it's nothing silly like £400!!! gulp!
    Thank you to everyone who replied!
  1. How often do you just go for a drive?
    By PANDY 3.2 V6 in forum General Motoring Chat
    Last Post: 16th July 2012, 14:19
  2. Yay... I can drive again
    By jimbojetset in forum General Chat
    Last Post: 12th May 2011, 08:47
  3. this maybe fun to drive...
    By hagga in forum The 'Off Topic' room
    Last Post: 6th March 2011, 09:15
  4. went for a drive
    By Grimo72 in forum General Chat
    Last Post: 28th February 2010, 21:40
  5. my vec not drive!!!
    By macane in forum Engine & Drivetrain
    Last Post: 10th January 2009, 16:12
no drive but i can get it in all gears vectra 1.8 sri
