Results 1 to 10 of 19
Thread: Why does car slightly hunt? 1.8
    Regular Member Jow20's Avatar
    Sep 2010
    Leeds
    Default Why does car slightly hunt? 1.8
    As above very slightly hunts at idle any obvious cause? Or could it be lots? Ta
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    i would start with a good clean out of the throttle body and its connecting pipes... use some carb/clutch cleaner spray
    East Midlands
    Throttle body needs cleaning??maybe.
    East Midlands
    Look at that hey nige both bang on time.lol
    Sep 2010
    Leeds
    Any "how2" lads? Could me as an amatur do it?
    East Midlands
    Quote Originally Posted by Jow20 View Post
    Dead easy mate,just remove air cleaner and spray some carb cleaner into the body its self,no need to remove the body unless you want to remove the gasket and renew it.
    Jun 2009
    South Coast
    as stated above..,, plus i tend to use and old tooth brush and scrub the inside out and wipe it out with decent non fraying rag... I also remove the breathee pipes and blow through them, if needed i push a paperclip through the blocked airways on the TB..
    Sep 2010
    Leeds
    Sorry to sound dumb! What is the air cleaner? Will i isntantly see the throttle body?
    Jun 2009
    South Coast
    from the airbox follow the plastic pipework to the engine, this black plastic pipework attaches to the top of the throttle body (TB).. undo the jubilee clip that holds this on and lift it off and push it over to the side while you clean out the TB.. inside the TB you will see a brass coloured 'butterfly' valve that turns on its central pivot pin, you need to wipe this down (both sides by hand) and especially its edges that cause it to stick, it is spring loaded but will turn easily enough using your fingers.. Do not worry, you cannot break it unless you clean it with a hammer. By airways i refer to where the little rubber pipes attach to the TB, whilst the pipes are off push something thin through like a paperclip in case they are blocked with soot or similiar. Just do not drop things into the throttle body, you do not want to leave any foreign objects in there..
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Quote Originally Posted by macdad View Post
    So no need to remove it, nice, want to do mine but don't fancy removing mine either. Is it ok to push the butterfly open to do both side?
    Heres what it looks like Jow.
  1. The hunt is on
    By Angel1368 in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2012, 12:55
  2. boot spoiler hunt!!
    By mikeyn84 in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2012, 10:41
  3. Family Egg Hunt
    By Tadpole in forum Quick Photo Album
    Last Post: 13th April 2009, 08:53
  4. hunt for vectra??
    By vectragsi3.2 in forum Vectra C / Signum Car Chat
    Last Post: 27th February 2009, 09:29
  5. Car hunt
    By Ian in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2006, 00:27
