ate the alf adjustable? my drivers side xenon seems to point inwards while stationary
Cheers Pete
Cheers Pete
is the afl light flashing on the dashboard, sounds like you've got a stuck motor, either that or it needs adjusting via the allen key hole at the top of the headlamp
no there is no flashing lights at all presume a garage will need to adjust them?
My passenger one sometimes sticks but the warning light will illuminate on the dash when this happens mate,has this just happened all of a sudden?
ive only had the car a week mate so not sure, was hoping there could be an easy fix or it will be going back under warrantee
any ideas???
Make sure you get it fixed if its under warranty mate as I tried to get mine fixed under warranty but the warranty company declined to replace headlamps due to cost of replacements at 500 ish quid a headlight, mine are usually fine but if I leave the car unused for any length of time the passenger side sticks but as plasma says you may get away with oiling the mechanisms hth mate
