Results 1 to 10 of 23
Thread: Whizzing Noise
    Apr 2012
    Wexford
    Trim : SRI
    Engine : 1.9 150
    Mileage : 146,000
    Default Whizzing Noise
    Well lads, i have a whizzing noise coming from the car, it only started a few days ago, its somewhere around the aux belt, i took off the belt and spun all the pulleys and alternator but cant feel any roughness or hear any noise from them. When the car is running on idle theres also a slight kind of rattle/ticking sound which gets louder if the steering is turned or lights turned on which i guess is because there is more pressure on the alternator, but i still cant make out which pulley its coming from or if its the alternator
    Another thing which i think could be coming from the same cause is when im driving, say accelerating from around 2,000rpm i can hear a ticking noise coming from the drivers side ( i cant hear it with the passenger window down or with both windows up)
    So im just wondering if this is a common thing or if anyone else has had the same problem and fixed it, because the womans vectra is making the exact same whizzing noise and has been since she bought it about 10 months ago although hers isnt making the ticking noise!
    i just dont want to go changing the 3 pulleys and alternator before i find out its just one of them!!
    Apr 2012
    Wexford
    Trim : SRI
    Engine : 1.9 150
    Mileage : 146,000
    Anyone any ideas before i start ordering parts??
    Jul 2012
    United Kingdom
    Mine was doing the same until I put a new belt on - problem solved!!!!.
    Might be worth a try for you.
    DAVY
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 98000
    it could be the alternator itself as when the lights go on or steering turned more load is put apon the alternator to supply more power,
    Apr 2012
    Wexford
    Trim : SRI
    Engine : 1.9 150
    Mileage : 146,000
    it was the belt itself doing it?
    Yeah was thinking alternator, but wa thinking as more pressure comes on the alternator there would be more pressure on all the pulleys with the belt being thighter....
    Sep 2010
    cornwall
    Trim : SRI
    Mileage : 98000
    glad you found out before too much outlay
    Apr 2012
    Wexford
    Trim : SRI
    Engine : 1.9 150
    Mileage : 146,000
    Oh no i didnt mean it was the belt on mine, that was at dmcc
    Im going to try the tensioner first as thats the only thing i can think would be making a ticking noise aswell, because its spring loaded and the others are just rolling...
    is this the correct part?
    http://www.ebay.ie/itm/SNR-Tensioner...item2322263a17
    Carnoustie
    This is just a guess! could the ticking noise be the clutch on the a/c pump? I have the whirring noise also and changed the alternator, the tensioner but noise persists!
    Ronnie
    Apr 2012
    Wexford
    Trim : SRI
    Engine : 1.9 150
    Mileage : 146,000
    i havnt a clue now to be honest, i tried switching the A/C on and off and it doesnt make any difference to the noise... i think its just going to be a case of trial and error
    Carnoustie
    Quote Originally Posted by Monkgti View Post
    I was convinced it was the tensioner so put brand new one on! did you try running it with the belt off to see if noise stops? should have done it on mine
    Ronnie
  1. Replies: 3
    Last Post: 8th September 2012, 12:13
  2. K&N noise?!
    By andylang in forum Vectra C / Signum Car Chat
    Last Post: 28th June 2012, 16:43
  3. Air con noise?..
    By bigdave1701 in forum Electrical & ICE (including SatNav)
    Last Post: 4th July 2011, 18:14
  4. Wheel Alignent or New Tyres? Noise Noise Noise
    By lostdog in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 13:29
  5. 1 noise solved (front Bearing) + 1 new noise (squeaking front brakes!!!)
    By joseantoniovalle in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2006, 08:54
